http://seattle.craigslist.org/sno/pts/2494250133.html
if it fits it ships! i neeeed posi and 3:73 i will check and verify of coarse. i have a spare 3.08 open ten bolt from an 85 sitting right now. will the parts cross over? thanks
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac 3''spintech prostreet mufflers xpipe 1 3/4 headers build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217 Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511 |
Re: will a 95 rearend fit?
nobody knows?
Some info here. http://67-72chevytrucks.com/vboard/s...d.php?t=396824
Looks like you might have an axle spline count mismatch.
1977 GMC Sierra Grande |
You also need to know if the rear end pictured is an 8.5" 10 bolt or a 14 bolt. They used both under those trucks . 1/2 tons had both but light duty 3/4 tons had the 14 bolt. Basically the same rear as a 90-93 454SS Truck but with 6 lugs. Since it has 3.73's it most likely came fron a 6 lug light duty 3/4 ton truck. If you buy the whole rear you can just have the axles redrilled or install Mosier replacement axles and will have a pretty strong rear. The 88-99 truck rears were only slightly wider . Barely noticeable.
Frank
Born and proudly residing in a Red State ! |
#5 | |
Yes they are 30 spline , you can use the guts for sure with the conversion bearings and I have been told you can take about 1/16 of an inch off the newer axles and they will work also . you can also buy 30 spline axles for our trucks
| Bookmarks |
