Old 07-17-2011, 08:53 PM   #1
yellow70
yellow70's Avatar
cab floor
Will a pickup cab floor fit in a 4x4 blazer ? how about the hump over the trans.? does it have to fit a 4x4 instead a 2 wheel drive ? Thanks
yellow70 is offline   Reply With Quote
Old 07-17-2011, 09:01 PM   #2
Bentblazer
Bentblazer's Avatar
Re: cab floor
I believe the floor will fit, but it will need to be a high hump for the 4x4 and will require a little sheet metal work behind the seats where it meets the header for the bed floor.
"85" Monte Carlo SS
"71" K5 (SOLD)
"64" Chevelle
1930 Chevy two door rat
Bentblazer is offline   Reply With Quote
Old 07-17-2011, 09:10 PM   #3
71swb4x4
71swb4x4's Avatar
Re: cab floor
If you have a low hump floor you are putting into your 4x4 Blazer you can easily cut the low hump out and bolt a high hump in. The low hump was part of the floor but the high humps are simply bolted in.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 07-17-2011, 09:19 PM   #4
yellow70
yellow70's Avatar
Re: cab floor
Thanks,any help is greatly welcomed !
