Old 07-18-2011, 09:17 PM   #1
Buzzman
Buzzman's Avatar
Speedo cable w/ cruise...
Hey There.
First post, hopefully of many. I've just gotten my second square-body, a 79 Cheyenne SWB. Goodwrench 350, th400, stock stock stock other than that. Among a few problems is the broken speedo. This truck has cruise (which I don't plan on using), and thus the two separate cables - one from the gauge to the cruse thing on the inner fender, and one from the cruise to the tranny on the driver's side. My question is whether or not I can bypass the cruse all together and use one standard-length cable from the gauge to the tranny. Anyone done this? Thanks.
79 C10 Cheyenne SWB Daily Driver
Buzzman is offline   Reply With Quote
Old 07-18-2011, 09:22 PM   #2
Restrorob
The One And Only !!!
Restrorob's Avatar
Re: Speedo cable w/ cruise...
Sure it can be done, Just buy the cable for your same truck without cruise.
And..... If I don't do it someone else will !
93 Jeep XJ
88 Buick La Sabra
Toys;
88 TA-GTA in the works....
97 GMC Ext. Cab
Old 07-18-2011, 09:25 PM   #3
Buzzman
Buzzman's Avatar
Great, thanks for the reply. How about removing the whole cruise unit? Is it just a matter of plugging the vacuum lines to the carb? There's a bunch of crap going on back there and I'm a little hesitant...
Old 07-18-2011, 09:37 PM   #4
Restrorob
Restrorob's Avatar
Just remove all the parts and block the vacuum ports on the carb/intake and tape the wire plugs to prevent shorting on anything, I've removed them and added them over the years......
93 Jeep XJ
88 Buick La Sabra
Toys;
97 GMC Ext. Cab
Old 07-18-2011, 11:40 PM   #5
Buzzman
Buzzman's Avatar
Great, thanks! I'll let you know if I ruin anything
Old 07-19-2011, 11:48 AM   #6
jimbonice
jimbonice's Avatar
If you do want to run cruise, it is not that expensive to fix. When I bought my 1977 it had the cruise unhooked with one single speedo cable. I bought a new cruise transducer from rockauto and the proper speedo cables and it has been good ever since.
jimbonice is offline   Reply With Quote
Old 07-19-2011, 09:52 PM   #7
Buzzman
Buzzman's Avatar
Ok, got the cable hooked up, drove around the block... a miracle! It's alive!
Isn't it great when things work? Thanks for the help.
Old 07-19-2011, 09:57 PM   #8
Restrorob
Restrorob's Avatar
Kool !
Now where's those pics ???
93 Jeep XJ
88 Buick La Sabra
Toys;
97 GMC Ext. Cab
Old 07-21-2011, 05:30 PM   #9
Buzzman
Buzzman's Avatar
Smile Re: Speedo cable w/ cruise...
Hey Restrorob,
Thanks for all the tips - I'm planning on pulling the cruise unit this weekend, but had a question about the wiring. You mentioned taping the wires to prevent shorts. Could I just clip them from the unit on the fender and tape them there, or would this be done down below where all the other wiring is in the cab? Sorry for the dumb question, but electrical stuff freaks me out.
I'll get those pictures up, too
Old 07-21-2011, 06:04 PM   #10
Restrorob
Restrorob's Avatar
Buzz.... You can trace them back to where ever you like then cut them off, Just make SURE you cut each wire all by it's self. Cutting multiple wires at one time could be a awakening moment....
93 Jeep XJ
88 Buick La Sabra
Toys;
97 GMC Ext. Cab
