07-19-2011, 09:27 AM | #1 |
My Carbon Footprint
What lube do you use in your rear end? ;o)
Okay......jokesters welcome I guess!
Getting ready to drop the 3rd member into my 9" housing and was thinking about the gear oil and weight. I have quite a bit of left over Sta-lube that is rated at 80/90 GL-5 (whatever that means). It is a posi so I realize I will have to add a friction modifier. Is that the correct weight and does brand make THAT big of a difference? |
07-19-2011, 09:43 AM | #2 |
its all about the +6 inches
Re: What lube do you use in your rear end? ;o)
I always recomend synthetic
07-19-2011, 10:09 AM | #3 |
20' Daredevil (Ret)
Synthetic here also.... doubt if brand matters, but for the record, I have Mobil 1 75W-90 in my Eaton diff. Have used RedLine 75W-90 in others, no problems.
- Mike - 1972 K20 LWB 350/350/205 RIP El Jay |
07-19-2011, 10:15 AM | #4 |
My Carbon Footprint
I've been reading some interested stuff on the internet. I'm seeing where guys are actually NOT using a friction mod in used rear ends with older clutch packs. They are saying the friction mod can cause the clutches to slip even more. I do understand the need for it on DD and other applications to the rear end won't pop and click around corners. This is going in a car that will see about 2 mile trips at a time. I am not concerned about the clutches because it will get a spool if and when this one goes out. Car will also see a little 1/8th mile track time. This car is ONLY for testing my Holley carbs and is in no way a cruiser or entended for any real street use.
