![]() Join Date: Jun 2004
1972 Gas Tank Sending Unit
I've got an opportunity to purchase an NOS sending unit, number 6429115. However the parts book lists two. They also list a 6429117. Can anyone tell me the difference and what each is for?
We have a 1972 C10 with 350 and automatic and air. Thanks Last edited by makamer; 04-16-2011 at 12:43 PM. Reason: Clarity |
Re: 1972 Sending Unit
Anyone??
anyone? I need this info as well. That is if it's the same for a 68...
Doug Looking for a 67-72 short bed driver..... Last edited by m6z; 07-18-2011 at 09:01 PM. |
![]() Join Date: May 2007
One is probably 3/8" and the other is 5/16".
Turp Mcspray New life for an old 2wd, farm blazer http://67-72chevytrucks.com/vboard/s...d.php?t=505987 My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=342299 |
#5 | |
DND Trucks
![]() Join Date: Dec 1999
![]() Quote:
6429115 is for a '72 series 10-20 Suburban w/ a/t 350, 400 exc. 4/wd 6429117 is for a '72 10-30 Cab w/ a/t 350, 400 Hope this helps. |
Re: 1972 Gas Tank Sending Unit
Great info. Do you know if its the same for all years? I'm looking for a sending unit for a 1968.
Doug Looking for a 67-72 short bed driver..... |
#7 | |
DND Trucks
You didn't mention if you have a truck or sub., w/ V-8 or inline 6. But here's the ones for the truck V-8's: '68 series 10-30 Cab w/ 327, 396 and '69 all w/ 2bc 350 6428081 '69-'71 series 10-30 Cab w/4bc 350, 396, 400 6428361 Note: I think this one is the single pick-up 3/8" line Hope this helps. Last edited by Dave; 07-19-2011 at 08:13 PM. |
If the truck came from the factory with a 307 2 barrel carb they had the same sending unit as the 6 Cylinder up to year 69. That was the smaller fuel supply line 5/16 size I think. A simple brass fitting adapter fixes that. The older versions also have a small nut with an eyelet on the unit and the others had a simple push on elbow on the stem with no threads.
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL" "You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig." ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629" |
