Old 07-18-2011, 09:21 PM   #1
Telecasterjoey
78 blaser tach cluster into my 86?
So I just picked up a working tach cluster for my truck. My truck is out for paint again and I'm dieing to know if the tach cluster will just plug in and work?
I know I've gotta hook up the tach to the coil, 12v, and ground but other than that is that all there is to it? My truck came stock with no clock or tach just the normal simple cluster.
I searched and couldnt find a definite answer. Thanks!!! oh and here's a pic!
Telecasterjoey is offline   Reply With Quote
Old 07-19-2011, 07:31 AM   #2
motornut
78K & 79C Jimmys
motornut's Avatar
Re: 78 blaser tach cluster into my 86?
lights or gauges?
they don't wire the same and the sending units are different
if your truck didn't come with one it will have to be hardwired in
start by checking the paths on the circut board they have to be the same or some wires may need to move
sweet find BTW
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
Old 07-19-2011, 07:25 PM   #3
Telecasterjoey
Dang not what I wanted to hear lol but makes sense!
Old 07-19-2011, 07:34 PM   #4
79BIG10
I'm back with 2nd truck!
79BIG10's Avatar
Gauge hook ups are different and the speedo is different as well. Old school is mechanical and yours is electronic style. You "might" be able to get a way to change everything. What I would do is get a wiring diagram for the old and new styles and get a plug with enough wire leads for that bezel. This way you can change over but the senders may be different. Great find indeed but I would look at selling it on Ebay and maybe going with a different setup.
1979 Chevrolet Bonanza Big10 "Tootsie Roll"
1985 Chevrolet Silverado (wife's)
Member of the Southern Bowties Club
"Don't underestimate how sexy a fat man who drinks to excess can be." Homer Simpson
79BIG10 is offline   Reply With Quote
Old 07-19-2011, 08:01 PM   #5
Telecasterjoey
My speedo is mechanical ( just one nipple where the cable from the tranny clips) could I just put the tach in my stock cluster and just wire in the 78 gas gauge?
Old 07-19-2011, 08:49 PM   #6
79BIG10
79BIG10's Avatar
Your tach would have to be wired in correctly separate from the cluster printed circuit board along with the fuel gauge. This "should" work without using the cluster. You would just have to take out the wires or actually if you reinstalled the correct wired on the correct ccircuit then you could keep the wiring without hacking and then you would just have to wire in the tach. I would look for a diagram your model. You might have the wires already there for a tach but nothing to connect to due to using the same harness and plug into the cluster but the factory could have used the different level of trim circuitry board.
Old 07-19-2011, 08:51 PM   #7
1BadSS
NOT REALLY BANNED!
1BadSS's Avatar
Thats a 78+ cluster.
1987 Mustang Coupe - 2.7 Stroker, 78mm turbo, Stainless header, 3" Exh, FMIC, 160lb/hr Injectors, MS3, twin walbro 255's, 34psi. Eating V8's daily.
04 Pontiac GTO
04 Ford Mustang GT
68 C20 LWB stripper truck
73 K5 Cheyenne
76 C20 Sierra Crew SRW
88 K20 Suburban
I'm not hammering on metal just to hammer, i'm creating a piece of art.
1BadSS is offline   Reply With Quote
Old 07-19-2011, 09:09 PM   #8
Telecasterjoey
Good or bad thing for me?
Old 07-19-2011, 09:20 PM   #9
Telecasterjoey
The back of the tach just says coil, ground and 12 volt, and I have the harness for it.
Looking at the printed circuit it looks like it should just plug and go. I'll update u guys when I get the truck back
Thanks!
Old 07-19-2011, 09:43 PM   #10
motornut
78K & 79C Jimmys
motornut's Avatar
be carefull doubt the coil wire is actually there
it would look right to plug in but ,follow the wires
like the gas gauge wire and others need to move in the plug itself
if you don't wana fry that cluster
i'd just wire the tach to the 86 cluster if it all works
did you score it at a junk yard ?
maybe this will help sort it out
John
Old 07-26-2011, 06:06 PM   #11
Telecasterjoey
Here's a pic of the cluster all cleaned up and needles painted. I get my truck back tomorrow cant wait to put the cluster in! Also I cleaned and painted my fender emblems.
Old 07-26-2011, 09:00 PM   #12
motornut
78K & 79C Jimmys
motornut's Avatar
looks good
hope it's all workin for ya!
John
Old 07-27-2011, 10:13 PM   #13
Telecasterjoey
So I'm in the process of hooking up the tach, where on the distributor do I plug the tach into? All the guages seem to work I just traced the wires and the are the same!
If anyone has a pic of how they hooked the stock tach into their stock distributor that would be great!
Old 07-27-2011, 10:24 PM   #14
J Knight
J Knight's Avatar
It hooks up right beside power lead to dist.
John
82 Chevy Silverado 350ci/TH350
J Knight is offline   Reply With Quote
Old 07-27-2011, 11:54 PM   #15
Your41Plague12
Your41Plague12's Avatar
Directly on the distributor, right beside the power wire. Right on the cap, you can't miss it.
Steve
Member of the Foot Pedal Club
'83 Chevy K20: 6" Rough Country, 3" Performance Accessories BL,
Bushwacker Cutouts, 38x15.50 Mickey Thompson Baja Claws,
350 HP 350 crate engine from Jegs, Turbo 400
Your41Plague12 is offline   Reply With Quote
Old 07-28-2011, 12:04 AM   #16
Telecasterjoey
Thanks guys, I dont have the clip though, I guess I'm going to have to find one similar and clip it beside the power wire.
Old 07-28-2011, 08:31 AM   #17
motornut
78K & 79C Jimmys
motornut's Avatar
a normal crimp on size will work
this is one i removed from mine.....wasn't workin right
John
Old 07-31-2011, 08:30 AM   #18
Telecasterjoey
Thanks guys, I've got it wired up and it works great! The only weird thing is when I shut the truck off the tach goes haywire. If I then turn the ignition on again the tach zeros out. When the truck is on it works perfectly. Is this just something they do? Or is the tach on it's way out?
Thanks!
Old 07-31-2011, 09:32 PM   #19
motornut
78K & 79C Jimmys
motornut's Avatar
how does it go haywire?
any ive seen sit off 500rpm to 1000rpm when off
but zero when key on
John
Old 07-31-2011, 09:53 PM   #20
Dan1969
It's probably because the distributor slowing down and the read on each lead... maybe a resistor would help on the line but hard to tell the valence. So for everything else did it bolt right up or had to make some adjustments? I hvae a 1980 K10 and got a cluster from a 1978, haven't installed it either.
Dan1969 is offline   Reply With Quote
Old 07-31-2011, 11:43 PM   #21
Telecasterjoey
it works great and is really responsive. When i turn the engine off it does a 3/4 turn counter clockwise sometimes more sometimes less. The cluster just bolted in with no modification!
Old 08-01-2011, 08:26 AM   #22
motornut
78K & 79C Jimmys
motornut's Avatar
good it works but yup that sounds weird
John
