Old 07-19-2011, 04:57 PM   #1
swierker
swierker's Avatar
Straightening slightly overbent U bolt - how??
One of the new U bolts for the coil rear on my 70 is slightly overbent on one side. How would I go about straightening it enough so I can get through the pads on the axle (or at least hold it open to get it on)? It's about 1/8"-1/4" bent in too much on one side. It doesn't look like a BFH would do it. I can get pics soon if it would help.
1970 Chevy LWB - 305/350
In Progress: 4/6 ECE drop, front discs, power brakes, Coys C5's.
swierker is offline   Reply With Quote
Old 07-19-2011, 05:10 PM   #2
YBNORML
YBNORML's Avatar
Re: Straightening slightly overbent U bolt - how??
I would put one side in a vice horizontally, then using a large pipe that you can slide over the other end slowly pull or push the u-bolt. Depending on what you need. I would also protect the threads before straightening.
Jason.
68’ GMC shortbox
72' 2WD Blazer
67' LongBox C-10
InstaGram ybnorml67
Old 07-19-2011, 05:14 PM   #3
swierker
swierker's Avatar
Thanks! Didn't even think of that one. I'll give that a try.
Dan
Old 07-19-2011, 08:31 PM   #4
swierker
swierker's Avatar
Thanks again. That worked like a charm
Old 07-19-2011, 09:34 PM   #5
YBNORML
YBNORML's Avatar
Your welcome
Jason.
68’ GMC shortbox
72' 2WD Blazer
67' LongBox C-10
InstaGram ybnorml67
