Old 07-16-2011, 08:54 PM   #1
youwish2bme
youwish2bme's Avatar
[86] Vacuum line diagram
Guys I'm trying to sort out the vacuum lines on the 86 that I'm working on to get them hooked back up. Is there a diagram of the vacuum lines set up? I know from some other forums I frequent that sometimes a picture is worth a thousand words. Does anyone have a picture with the vacuum lines set up on a 86? Thanks guys!
Dave
The toys shoe horned into the garage for the storms....
http://img.photobucket.com/albums/v1...2bme/SIG-2.jpg
youwish2bme is offline   Reply With Quote
Old 07-17-2011, 09:09 PM   #2
youwish2bme
Re: [86] Vacuum line diagram
I've been searching the archives and haven't found a good picture yet. Does anyone have a stock 86 that could take a few pics of the vac lines? Thanks!
Dave
Old 07-18-2011, 02:38 AM   #3
Blake_H
Blake_H's Avatar
Here ya' go. Hope it helps.
Blake_H is offline   Reply With Quote
Old 07-18-2011, 11:15 AM   #4
JAG66
Dave, now you can buy 100 feet of vacuum hose. Good to hear you're working out a few kinks I never got to.
JAG66 is offline   Reply With Quote
Old 07-18-2011, 11:29 AM   #5
michael bustamante
michael bustamante's Avatar
HAVE FUN. I had to replace all my vacuum line and it took forever! 1 piece at a time!! it took 14 feet for me. i dont know they cant make line that lasts longer than 25 years!
1967custom
michael bustamante is offline   Reply With Quote
Old 07-18-2011, 11:32 AM   #6
youwish2bme
No worries brother! Just working on the truck the same as you were. She runs great just looking to see what was disconnected by the previous owners...
Old 07-18-2011, 01:33 PM   #7
Stoney
Farm Truck
Stoney's Avatar
It's actually pretty easy. Just time consuming. Were does the AC vaccum line tie into?
1969 CST/10
1984 K5 Blazer 4x4
2016 Dodge Ram 2500 4x4
Mike
Jersey Village, Tx
Stoney is offline   Reply With Quote
Old 07-18-2011, 02:08 PM   #8
youwish2bme
Right now the line is hanging free from the firewall... Or were you talking about on the diagram?
Dave
Old 07-19-2011, 12:55 PM   #9
Malo83
Cruzzzn' Vet
Malo83's Avatar
This is the snake pit on my 83
Uploaded with ImageShack.us
Malo83 is offline   Reply With Quote
Old 07-19-2011, 01:12 PM   #10
Stoney
Farm Truck
Stoney's Avatar
That's my problem, too. I can't figure out were the line hanging from the firewall goes?
I don't see it on the diagram.
1969 CST/10
1984 K5 Blazer 4x4
Mike
Jersey Village, Tx
Old 07-19-2011, 09:09 PM   #11
youwish2bme
Its not on this diagram it is part of the heat/ac system. It provides the vacuum source for the three (3) vacuum cans inside the cab that control the doors inside the heater/ac box. The three cans control the defroster duct, recirc for MAX AC and the last is the one that selects vent or feet...
I found out tonight two of the three work..
Old 07-19-2011, 09:29 PM   #12
Stoney
Farm Truck
Stoney's Avatar
I guess that's a good reason why mine doesn't work.
Thanks for the info. So do you know were it supposed to go?
1969 CST/10
1984 K5 Blazer 4x4
Mike
Jersey Village, Tx
Old 07-19-2011, 09:44 PM   #13
youwish2bme
Yeah, sorry.. The line needs to be connected to a check valve that has a total of three ports. The first should be to supply manifold vacuum, second will be after the check valve to the line and the third is also after the check valve and goes to the vacuum tank located on the LH side of the firewall below the wiper motor. The tank is there to supply vacuum under high load conditions when you loose manifold vacuum. Hope this helps.
Dave
Old 07-19-2011, 09:58 PM   #14
Stoney
Farm Truck
Stoney's Avatar
Okay Thanks, I'll check it out.
1969 CST/10
1984 K5 Blazer 4x4
Mike
Jersey Village, Tx
