Old 07-19-2011, 10:56 PM   #101
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: Project: Ginger
Originally Posted by milner View Post
Looks good man, between your's and n2billets I really want a stepside now
Thanks.
I've never been a fan of the stepsides.
I'm just working with what I have.
But since n2billet finished his stepside,... aka "Stella Mae",... I've changed my mind.
Keith
Convert to disc brakes.
Old 07-19-2011, 11:47 PM   #102
litew8
litew8's Avatar
Re: Project: Ginger
Right above the first hole for the radio is one area. Maybe it's just the lighting.
litew8 is offline   Reply With Quote
Old 07-21-2011, 09:34 PM   #103
lolife99
lolife99's Avatar
Re: Project: Ginger
Small update.
Installed the refurbished "plain" 3-hole dash cluster,
(the flash on my phone camera makes the needles look a different color,... but they are the same).
Also plumbed the trans cooler with 6AN braided hose.
Keith
Old 07-21-2011, 09:38 PM   #104
67cheby
67cheby
67cheby's Avatar
Re: Project: Ginger
clean...super nice work
67cheby is offline   Reply With Quote
Old 07-21-2011, 09:39 PM   #105
VA72C10
VA72C10
VA72C10's Avatar
Re: Project: Ginger
Nice job!!!
Old 07-21-2011, 09:43 PM   #106
1stchevy
1stchevy's Avatar
Re: Project: Ginger
Coming along nice! I wasn't a step side fan but you guys are making me rethink that.
1stchevy is offline   Reply With Quote
Old 07-21-2011, 10:08 PM   #107
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
Re: Project: Ginger
Im glad your finally making a thread!
John
1999 Toyota Tacoma 4x4
Old 07-21-2011, 10:35 PM   #108
70k52wd
Blaze-Air
70k52wd's Avatar
Re: Project: Ginger
Step sides are killer when the altitude is properly adjusted.
Nice, umm, everything.
70k52wd is offline   Reply With Quote
Old 07-22-2011, 06:12 PM   #109
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Re: Project: Ginger
Looking good Keith!
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 07-22-2011, 06:25 PM   #110
Painter D
Painter D's Avatar
Re: Project: Ginger
Originally Posted by 72blckbuty View Post
looking good keith!
x2
'58 SWB Fleetside...Front & Rear Porterbuilt Dropmember, 6.0 LS /4L60E. Accuair E-level, 20 Billet Specialties (Vintecs)
'63 Buick Riviera ... AccuAir E-level, 20" Billet Specialties (Vintecs)
http://67-72chevytrucks.com/vboard/s...=528853&page=5
Painter D is offline   Reply With Quote
Old 07-22-2011, 06:54 PM   #111
big_al_71
big_al_71's Avatar
Re: Project: Ginger
terrific job....
Get your facts first, and then you can distort them as much as you please!!!!!.
Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild
big_al_71 is offline   Reply With Quote
Old 07-23-2011, 10:18 PM   #112
lolife99
lolife99's Avatar
Re: Project: Ginger
Made a little progress today.
I installed the glovebox liner (of course,... 2 screw holes didn't line up. Poor quality aftermarket crap).
Polished the original glovebox door and installed it.
My air compressor crapped out last week.
The new check valve showed up today.
So I got that installed,... and had shop air to run my tools again.
The big project was rebuilding my vent windows.
I talked to several members and decided to buy a "Rivet Tool" to install the "factory style" rivets.
I bought the vent window rivet tool from here:
http://www.zip-corvette.com/ProductD...L2-SR&CTitle=&
I bought this tool because I have a few more vent windows to do, on my other trucks.
(plus,... I like specialty tools)
The rivet tool worked great,... but I think a second set of hands would have made this job slightly easier!
I had some rivet left over from rebuilding my air vents.
I purchased them from Classic Parts of America.
http://www.classicparts.com/1951-87-...ctinfo/03-825/
I needed a way to do this by myself.
I used a 5/8" x 1-1/4" x 22" piece of steel in my vise.
The 5/8" thickness is perfect for the window channel after the weatherstrip has been removed.
I also used a piece of 5/16" key stock to help rivet the oem pivot bracket back into position.
(I switched heads in the tool and was able to rivet the second pivot bracket without the key stock)
The first vent window took a little while to figure out.
The second one went much faster.
A small cut-off wheel in my air 90 grinder worked great for removing the necessary rivets.
A drill was also used to get to a few rivets.
I also used new rubber seals from Steele Rubber Products.
https://secure.steelerubber.com/search_frameset.php
Here's a few pics,...
Keith
Old 07-23-2011, 10:35 PM   #113
VA72C10
VA72C10
VA72C10's Avatar
Re: Project: Ginger
Nice work! That's one job I'll leave to someone else
Old 07-23-2011, 10:35 PM   #114
lolife99
lolife99's Avatar
Re: Project: Ginger
I know it doesn't look like much,... but they are ready to install.
I swapped out the window locks,... from another set that wasn't so pitted.
Tomorrows project is new window weatherstrip and 1 regulator install. (because 1 is backordered),... and installing the vent windows.
Here's my workbench after todays "little" project. Ha.
Keith
Old 07-23-2011, 11:05 PM   #115
mcbassin
Still Learning
mcbassin's Avatar
Re: Project: Ginger
Nice work on the wing window rebuild. I'm diggin the shop made throttle cable bolt you made. You got some skills bro. I like the way you think for sure. Keep the fast update coming.
Old 07-23-2011, 11:09 PM   #116
lolife99
lolife99's Avatar
Re: Project: Ginger
Thanks.
This thread is making me work on the truck.
Keith
Old 07-23-2011, 11:11 PM   #117
VA72C10
VA72C10
VA72C10's Avatar
Re: Project: Ginger
The chrome on those look really nice. Were they just a nice original set or did you re-do that?
Old 07-23-2011, 11:16 PM   #118
lolife99
lolife99's Avatar
Re: Project: Ginger
The pics don't show how bad they are.
They have minor pitting.
My truck has black/rusty vent windows,... and I didn't want to completely remove the glass and powdercoat or paint the frames,... so I'm adding these originals, that I got from member Teeitup.
My blazer and my red '69 have SUPER nice chrome vent windows.
I just haven't been able to fine a nice set for Ginger.
So these will be fine for this old truck.
Keith
Old 07-23-2011, 11:55 PM   #119
STP67-72
STP67-72's Avatar
Re: Project: Ginger
Truck looks great. Keep em coming. I got to order one of those tools for vent windows.
55 Chevy original swb (big back window)
61 Chevy bubble top (427-5 speed)
67 Chevy stepside (Krusty)
68 Chevy swb fleet (Lola)
68 Chevy swb fleet
71 Chevy swb fleet ( future PB project)
97 crew cab power stroke
07 SS Trail blazer
STP67-72 is offline   Reply With Quote
Old 07-24-2011, 09:29 AM   #120
bollybib
bollybib's Avatar
Re: Project: Ginger
Seems like every time I tackle an "easy job", I end up with a mass of tools strewn around the project just like that.
- Jim -
My Daily Driver is a 1969 Chevrolet Custom/20 Fleetside 350/TH400/Eaton H052 4.10
and its Project thread is here http://67-72chevytrucks.com/vboard/s...d.php?t=456911
bollybib is offline   Reply With Quote
Old 07-24-2011, 12:05 PM   #121
hot trux
'85 Stepside
hot trux's Avatar
Re: Project: Ginger
LOOKIN GOOD MAN!!!
hot trux is offline   Reply With Quote
Old 07-24-2011, 12:45 PM   #122
n2billet
Village Idiot....
n2billet's Avatar
Re: Project: Ginger
Originally Posted by hot trux View Post
LOOKIN GOOD MAN!!!
I agree....
http://www.hubgarage.com/mygarage/n2billet
-67 SWB Custom Porterbuilt Front and rear 20/22's Hazel Sold
-71 StepSide Porterbuilt Stage 2 with 20/22's Stella Mae Sold
n2billet is offline   Reply With Quote
Old 07-24-2011, 07:35 PM   #123
lolife99
lolife99's Avatar
Re: Project: Ginger
Another small update.
Today I installed my tilt column.
I purchased a rebuilt tilt from member KevsClassics.
http://67-72chevytrucks.com/vboard/s...d.php?t=264748.
This is my second tilt column that I've bought from Kevin.
The quality of his rebuilds are second to none.
Also got the brake pedal adjusted for the Wilwood M/C.
I had it set,... but then after installing the column and the lower bracket (with the brake pedal rubber bumper) changed the final position of the push rod.
I think the M/C is on for good now.
The other project was replacing all window weatherstrip and installing the newly rebuilt vent windows.
This was a battle of "aftermarket parts".
I ordered all my weatherstrip from Classic Parts of America.
The door glass channel and division bar gaskets were fine.
The window "fuzzys" (seals) were terrible.
They are coming back off.
(I've already ordered new window seals from Steele Rubber Products).
I also installed new window regulators.
The LH side was back ordered from Classic Parts.
So I installed the RH regulator.
Typical job that would be better with two people,... but it works great.
Since I wanted to get the drivers side done,... I decided to use a NOS regulator that I purchased here in the classifieds.
The NOS regulator has a rub in it.
Like metal to metal in a just one spot.
Aftermarket wins this time.
Here's some crappy cell pics,...
Keith
Old 07-24-2011, 07:39 PM   #124
lolife99
lolife99's Avatar
Re: Project: Ginger
I know the tilt column doesn't fit the "plain jane" truck theme,... but I'm going to lower the seat brackets,... so it's a necessity.
Plus I needed an auto column since this truck originally had a 3-speed column.
Keith
Old 07-24-2011, 07:52 PM   #125
mcbassin
Still Learning
mcbassin's Avatar
Re: Project: Ginger
Nice work Keith and no worries about the tilt. I think they are near mandetory anyway. It looks like Kevin does a first class job on the tilt rebuilds.
