Old 07-21-2011, 07:25 PM   #1
57 3100
57 3100's Avatar
SBC waterpump measurement
guys,
does anyone know the measurement difference between a short and long water pump ?
im running a 1980 350 out of a truck with long water pump, alternator on passengers side, and got some late 60's SBC alternator brackets to switch the alternator to the drivers side, but those motors use a short water pump. i need to make a spacer to make up the difference and want it to be exact.
thanks
leonard
57 3100 is offline   Reply With Quote
Old 07-21-2011, 08:04 PM   #2
57 3100
57 3100's Avatar
Re: SBC waterpump measurement
found it guys, thanks anyway....
5.875 short pump and 7.250 for a long pump.
Old 07-21-2011, 10:49 PM   #3
OrrieG
OrrieG's Avatar
look at my build thread towards the end. I have hours in figuring out my brackets and pulleys. working on the ac bracket tonight. long water pump.
Old 07-22-2011, 04:26 AM   #4
57 3100
57 3100's Avatar
sure will, and thanks for the help..... i will look through it tonight when i get off work.
leonard
Old 07-22-2011, 01:31 PM   #5
OrrieG
OrrieG's Avatar
I wasn't bright enough to figure out ahead of time, I just accumulated different steering and alternator bracket set ups and used/modified them to work. I originally had the alt on the passenger side using factory LWP set up, but moved it over to the driver side. Mine is complicated because I am using the stock front motor mounts that on 58+ auto and 60+ trucks were used for mounting accessories. But I enjoy the figuring out and fabrication so its ok for me. Also your exhaust manifolds will affect what you are doing, I used stock ram horn type with the cast bracket for driver generator.
Old 07-22-2011, 09:39 PM   #6
57 3100
57 3100's Avatar
thanks man, just checked out and subscribed to your build thread. i like the way you use cardboard to make templates. im a welder full time and also love fabbing stuff up.
i got me some alternator brackets form a late 60's 327, for drivers side, but because of the long water pump, i am having to modify the brackets. i think i have it half figured out, and will know more on sunday when i mess with it more. i will post pics when i do get it up and going.
thanks again....
Old 07-23-2011, 04:18 PM   #7
RootBeer 6117
RootBeer 6117's Avatar
Lot of good bracket/pulley info here
http://www.alangrovecomponents.com/Important_Info.htm
RootBeer 6117 is offline   Reply With Quote
Old 07-24-2011, 07:11 AM   #8
57 3100
57 3100's Avatar
wow, great info there... thanks a bunch... i should be real close to being finished with my setup today, and will post pics when its done.
leonard
