Old 07-21-2011, 06:58 AM   #1
coggonobrien
what is max lift and still successfully pull a loaded trailer?
Just trying to decide between a 4 inch lift and 35's or a 6 inch and 37's with my 68 swb running 52 inch springs. we have a 24ft tilt bed trailer and will pull cars/ pallets of seed on occasion.
Thanks,
David
coggonobrien is offline   Reply With Quote
Old 07-21-2011, 09:43 AM   #2
'63GENIII
'63GENIII's Avatar
Re: what is max lift and still successfully pull a loaded trailer?
Over the years I've had both 4" with 33-35's and 6 - 8" with 38's to 44's and have towed cars, boats and trailers full of rock ect. I will say that my tolerance for the "pucker factor" that the 6" and up lifts can produce while towing (and sometimes when not towing) has decreased. 4" and 35's are my limit now. It all depends on your limit and driving ability.
Chris
'63 k15 long step
Vortec 7.4 - L29 Blackbear tune, Five 0 Motorsports injectors, Chris Straub Cam, NV4500, divorced 205
52" front and 63" rear spring swap
D44 / 14bff - disc axles
Milemarker 9K and 10.5K hydraulic winches
63" & B52 Spring Install http://67-72chevytrucks.com/vboard/s...ng+swap+thread
NV4500 Reverse Build Thread http://67-72chevytrucks.com/vboard/s...=reverse+build
L29 - 7.4 Vortec Build http://67-72chevytrucks.com/vboard/s...&highlight=L29
'63GENIII is offline   Reply With Quote
Old 07-22-2011, 12:38 AM   #3
coggonobrien
gotcha, i figured geometry wise the 4/35 combo would be the absolute max but thought i would check.
THanks!
Old 07-22-2011, 10:03 AM   #4
ghettoluxury
ghettoluxury's Avatar
THanks!
4 with 35"s is a good setup for pulling a trailer. If you have a gooseneck it will still fit in there with no mods. My buddy pulls a gooseneck wit 39.5 pitbull rockers and we had to chop his trailer up so that he could do so.
1949 Five Window, 1973 Step Side, 2000 Z71
ghettoluxury is offline   Reply With Quote
Old 07-22-2011, 01:34 PM   #5
maskale
depends on what ur pulling and the terrain.
Just because the truck will pull it dont mean u should. U have to consider emergency case senarios, lifted with a swaying trailer will never be good.
either way, stay short and light.
u wont find any writen specifications, all manufacturers are gonna say not to tow with a lift.
maskale is offline   Reply With Quote
Old 07-22-2011, 04:05 PM   #6
Redcap
I frequently tow a trailer, often with a total trailer weight of 8k+, with my K20, which is lifted 6" and runs on 35x12.5s. Tows and stops just fine (with trailer brake controller, of course).
Redcap is offline   Reply With Quote
Old 07-22-2011, 06:43 PM   #7
Mr. 250r
Mr. 250r's Avatar
I agree with maskale basically any truck can tow but you gotta set the limit on your weight also trailer sway is a nightmare I almost lost my first suburban because of it and we ended up across the road which was from how it was loaded and that can make the biggest difference towing and for lift kit towing depending on the lift and the weight and if the truck is 1/2 3/4 or 1 ton
1987 Chevy V30 - http://67-72chevytrucks.com/vboard/s...d.php?t=573854
1988 IROC-Z Camaro - 305/T5 T-Top
1989 GMC V35 - Marbolo Express http://67-72chevytrucks.com/vboard/s...d.php?t=596850
1991 V2500 Suburban Silverado - Sold
1991 V2500 Suburban Scottsdale - Big Nasty http://67-72chevytrucks.com/vboard/s...d.php?t=497423
2001 Ram 3500 5.9 H.O NV56 EC DRW - Sold
2003 1500 Silverado
2004 Ram 3500 5.9 H.O NV56 CC DRW - Sold
2005 Silverado 2500HD 6.6/ZF6 CC LWB
Mr. 250r is offline   Reply With Quote
