#501 |
Re: Lurker OrrieG Progress Pics
Yeah we have been thru that with former dogs.
#502 |
HOW long until spring??
![]() Join Date: Mar 2009
Orrie, Are you coming to Motorfest?? Maybe we can get the bunch of us together while the show is going on if Dave promises to behave.
http://67-72chevytrucks.com/vboard/s...d.php?t=469913 Bubba
69 chevelle convertible 71-C-10 short-wide and low ![]() 64 C-10 custom shortbox "Bubba"s Recycling project" |
#503 |
Don't know, I will be out of town the week before that visiting my grandkids, could probably slip away for an afternoon or evening. I will subscribe to the other thread. Thanks for the heads up.
#504 |
Got home and the 3 groove pulley I needed has arrived. Guy even cleaned it up before shipping so all I have to do is scuff and paint. Now I can button up the front end of the engine. Need to fab an ac bracket, but need the dims for a Sanden 508 compressor (post in main message forum).
1959 Chevy Short Fleetside w/ 74 4WD drive train (current project) OrrieG Build Thread 1964 Chevelle Malibu w/ 355-350TH (daily driver) Helpful AD and TF Manual Site Old Car Manual Project Last edited by OrrieG; 06-17-2011 at 12:05 AM. |
#505 |
Google Sanden 508 Compressor Dimensions under Image search. I found it but you can only see the preview. If you click on it they try to charge you but you can still make out the dimensions.
#506 |
Thanks wheelie, I missed that in my search.
Today was good and bad. Bad is my 3 groove pulley does not fit, contrary to 3 places on different GM messages boards that said SB and BB are the same. I need PN 3972180 or 14023148, should have done more research. If anyone needs a 68-74 BB 3 groove crank pulley (used with a/c option) PN 3937787 I have one! Good is I got the back bumper extra holes welded up (PO had 56 car poorly fitted bumper guards) and scuffed with 80 grit for etch priming. Cleaned up the back side of it and painted it with rattle can Rustoleum in grey. Will spray undercoat after final paint. It had one pretty good dent that took an hour with an old school 2# ball peen hammer and cold chisel to move close to flush. Don't try that on your new truck. Sounded like a busy black smith shop when the calvary is in town. Cleaned up and painted the steering stabilizer. Fabbed and bracket for the trailer connector. Cleaned and painted aforementioned pulley. Also got the inside windshield/dash trip primed, working towards painting it, bumpers, door insides and grille insert in a couple of weeks the same color as the interior. Here is a photo of the pulley for grins, you can see its 1/2 pulley width to close to crank. Also a photo of the modified front bumper bracket, in a previous post I mentioned that the steering box covers the hole. I modifed it to take the place of one of the box mounting shims. Lots of trial and error, thank goodness for a welder, cut off wheel and grinder!
#507 |
Slow easy weekend, cleaned up the shop and got a few things done. Front steering stabilzer cleaned, painted and installed. Oil pressure line, did it twice, got the first one installed and found a kink that with vibration would start leaking. Wanted to keep it out of sight as much as possible. Also installed the auto trans kick down bracket. Mocked up a bracket solution for the ac. Big thank you to Tmoble for getting be photos and dimensions for the compressor.
#508 |
I think Old Air Products catalog has dimensions on the 508 - haven't looked but maybe it is on their website. Vintage Air at one time had the dimensions also.
#509 |
T-Moble took care of me with tape measured photos. Thanks
#510 |
I really like how your oil pressure line turned out! That looks really nice, that is one of the next few things on my list for sure!
Brian
current project; 1950 GMC "Junk Yard Dawg" http://67-72chevytrucks.com/vboard/s...d.php?t=635960 ___________________________________________ SOLD to "ONEBADFIVEFIVE" http://67-72chevytrucks.com/vboard/s...d.php?t=436406 |
#511 |
Second time was the charm. Painted and installed the valve covers, included a before shot too. Also installed the 3 groove bottom pulley (thanks to CustomBrad) found out I need to change out the upper from 7" to 6.25". Modifed the alternator bracket for the third time to move it one groove back on the pulleys, I thought the third groove extended in front of the standard two but it actually add one closer to the engine. Also dug out the grill and cowl top vent to start sanding.
#512 |
Looking good OrrieG.
Kim |
#513 |
I came up an old photo I had stored on the comp.
It would be a real upgrade to your truck in his before resto I had to share it with you Love your truck in his old skin gone make mine that way keep up the good work love all of your modifications "ït looked like a truck that was beaten with a tirearm" |
#514 |
The teal one looks like it might be a NAPCO. Serious front bumper. I just sold my winch because I could not get it to work with cutting up the stock bumper. Am going to just mount a receiver in the front for a portable I can use on the front or back depending on which end is in trouble!
#515 |
Chevy Enthusiast
I would love to have that 57, and im no expert but it does look look a napco.
Tony 1985 GMC K2500 restoration Project: Rust, White & Blue 1989 Chevy R3500 CC Cummins & 4X4 swap some day... 1989 Burb (D60, 14BFF, 12V, NV4500, NP205, 37" tires in progress) |
#516 |
Saturday was a good day. Went to Emmett swap meet and car show and scored the water pump pulley I needed for $5. When I got back home, picked up the grandson so he could help a little. Last week he mentioned to my wife that he might want to learn some auto stuff. I gave him a quick shop safety class (eyes, ears, fumes and hands) then turned him loose on the wire wheel to clean up the pulley. After that we painted and installed it. Then had him clean off the turn signal trim, needed laquer thinner to get old paint over spray off.
Finally let him buff out the big parts so he could see how a little work turns crud to bling. Here are some photos of him and the pulley. I hope it sticks with him, I enjoyed the company and fact I got twice as much done! Today just stripping paint off the grill insert and paintingt the inner turn signal lamp holders.
#517 |
Cool stuff OrrieG.
Kim |
#518 |
Orrie
Been awhile since I caught up with your work.... lookin good. Your making great progress.... wish I would have known about your winch, I might have been interested in it ![]()
http://67-72chevytrucks.com/vboard/s...d.php?t=385404 |
#519 |
Looking good! You keep up that pace, you'll be done before me! Glad you were able to find an upper pulley and got that part out of the way! Keep it up!
It's all about the stance, baby! http://67-72chevytrucks.com/vboard/s...d.php?t=320546 |
#520 |
Too bad we did not get together at the Emmett show , I was looking for you,
I pm'd you my Cell number , just not in enough time for you to get it.. Nice score on the pulley, I struck out and did not buy one thing.. Maybe next time... Good job on getting your grandson involved.. my daughter went with me to the Emmett night cruise and we were pleased that the younger generation was cruising around in older iron and not just in rice rockets. Good to know the traditions will live on....
69 chevelle convertible 71-C-10 short-wide and low ![]() 64 C-10 custom shortbox "Bubba"s Recycling project" Last edited by bubba327; 07-17-2011 at 11:26 PM. Reason: Added |
#521 |
Progress. 4 trips to the store to get the right fan belts, Goldilocks syndrom too small, too big, just right.... Also got the ac brackets fabed up and choke set up. I am using a q-jet with divorce coil type. I have about an hour and a half in getting the little rod bent just right, had to make three tries at it. I might get this thing fired up in a couple of weeks! Here are some detailed photos of my alternator and power steering mount, a member has asked for some detail. The ps mounts of the exhaust bolt and uses a long water pump with the bolt thru bracket receiver(??). Alternator uses ramhorn sbc maniford with boss for generator bracket with another angle to push it forward.
#522 |
looking real good OrrieG, im liking the fab work...
i HOPE to have my alternator mounted today. i too have been running back and forth to the auto parts store to get the correct length belt. LOL. hope i got the right one this time. question, on your alternator bottom through hole, did you notice some play before tightening up the bolt ? mine uses a .375 bolt and the hole in the alternator and bracket is .400, so there's .030 slop there..... im thinking of drilling the alternator and bracket holes to .437 and using a 7/16, .437 bolt to get rid of that slop... leonard
http://s251.photobucket.com/albums/g...G/1957%203100/ |
#523 |
I just used a 3/8" bolt (.375") with enough washers to get a tight interference fit between the alt support ears. It did have some slop, but that is not necessarily a bad thing if it tightens down. It allows for some adjustment to make sure the Alt is square to the pulleys and parallel to the engine long axis, you just need to sneak up on the tightening to make sure it is not torqued out of place. I built the same adjustments into the ac bracket, as shown it is parallell and square to the block and pulleys too. Wish I had the compressor so I could finish it up.
There were 400+ cars at a show I went to last week and you would not believe how many had misaligned pulleys. Tough on belts, bearings and prone to tossing belts at high RPM, especially if you have long runs like I do.
#524 |
hello again OrrieG...
got my alternator swap completed and you can check out the pics here. http://67-72chevytrucks.com/vboard/s...30#post4808230 i went ahead and drilled out the bottom pivot hole in the alternator and bracket to .437, 7/16 and that took care of my slop in that area.... being a novice machinist i always like tight fits. LOL. now i gotta order my a/c unit soon.... cant wait.. take care. leonard
#525 |
Sounds like good progress. Great day here, one of those where everything clicked. Got the fan on, radiator and shroud installed, got rad hoses that fit the first time, carb cleaned and started install. Rummaging around in the parts bin I found a prebent flared piece that mounted right to the fuel pump and clears the motor mount! So the carb is plumbed to. It looks a little ratty but for now I am just focusing on getting it running and when I get better financially I can upgrade. I think I might get it fired next week to test for leaks with just a hot wire to the HEI and cut off switch. This week will be checking fluids and remembering to plug the oil pressure gauge line so I don't soak the under dash area when it fires. It was a running engine pulled from a know truck so I know the pressure is fine and no cam to break in. Also, everything I have been buying is Made in USA, thanks to Gates and Dorman.
