Old 07-24-2011, 08:05 AM   #1
billtoothaker
Junior Member
Unhappy 67-72 AC clutch for compressor
Anyone ever replace just the clutch on the AC compressor in a 67-72 pickup? It is a Frigidaire model and is or was original. The shaft still spins in the compresser but the clutch smoked.
Bill Toothaker
72 K20 FSLB 63K
FS:86 Mercedes 560SL
63 Ford F100
51 Willy's Jeep station wagon w/64 289 Studebaker
68 Honda SL90 1500 miles
Chevy 6 cyl street rod
2011 Nissan Murano cross cabriolet
Cabins for Rent Lake Winnipasaukee, NH
billtoothaker is offline   Reply With Quote
Old 07-24-2011, 08:16 AM   #2
Eddie H.
Eddie H.'s Avatar
Re: 67-72 AC clutch for compressor
It is pretty easy if you have the right tools. You will need a puller that threads into the front of the hub, and some snap ring pliers. Remove the nut from the shaft, pull the hub, then remove the 2 snap rings that hold on the clutch and coil.
"Negative people always seem to have a problem for every solution"
Eddie H. is offline   Reply With Quote
Old 07-24-2011, 08:20 AM   #3
billtoothaker
Junior Member
Great, thanks Anyone have a good contact to buy one, I wnat to make sure i get the right one.
Bill Toothaker
72 K20 FSLB 63K
63 Ford F100
Old 07-24-2011, 09:50 AM   #4
cdowns
cdowns's Avatar
when i had mine replaced it was available at local parts store. carquest was the store i got mine i believe most others wood have it too
