Old 07-23-2011, 10:54 PM   #1
dave666693
dave666693's Avatar
Proportioning valve ??
Will a disc brake proportioning valve work OK on drums front and rear?
67 C20/
68 C10 stepside/inline 250--current project
71 GMC 4x4
70 Blazer project-Zombie assault vehicle
67 4x4 Burb
dave666693 is offline   Reply With Quote
Old 07-23-2011, 11:00 PM   #2
fastwillie 696969
~Rest In Peace~
fastwillie 696969's Avatar
Re: Proportioning valve ??
its a disc to disc PV or is it disc and drum PV ,i would think it would work being disc pv .
is it fast ? it has a lighting bolt donut?
B___H please, I can remove 90% of your so called "beauty" with a kleenex
fastwillie 696969 is offline   Reply With Quote
Old 07-23-2011, 11:48 PM   #3
Lee H
Lee H's Avatar
Please don't mix brake parts. You need those important safety parts to work correctly. Each brake component is designed and manufactured for a specific purpose and should not be mixed up. Easier to find the right part than to recover from an accident.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner.
1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components.
My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703
Lee H is offline   Reply With Quote
Old 07-24-2011, 06:28 AM   #4
Drum brakes and disc brake require different pressure characteristics and the purpose of the proportioning valve is to keep the pressure in the proper "proportion" in the two separate sides of the system controlled by one master cyl.
Old 07-24-2011, 11:39 AM   #5
Daddy Brim
Daddy Brim's Avatar
I agree with this .
I'm sorry I called you stupid. I thought you knew already.
67 C-20 Custom Camper
68 Nova 396 it does wheelies
2005 Buick Century the one the wife drives
1989 Toyota Tercel to drive when I can't put gas in the first 2.
Daddy Brim is offline   Reply With Quote
Old 07-24-2011, 12:06 PM   #6
lolife99
67-72 parts collector,…
lolife99's Avatar
Drum brake trucks have a distribution block.
It's not a proportioning valve.
Meaning,... it doesn't regulate the front vs rear brake pressures,... it just sends fluid to the 4 wheels.
Use the correct parts on your drum brake truck.
Keith
Convert to disc brakes.
Old 07-24-2011, 12:12 PM   #7
Gene
Gene's Avatar
What about using differentials from a truck that came with anti-lock brakes? Will the discs work fine with a stock 71 setup?
Gene is offline   Reply With Quote
Old 07-24-2011, 12:23 PM   #8
mbgmike
as stated use the correct part. Prop valves send 70% to the front and of course 30% to the back. Disc brakes need more pressure up front than the rears. So all you are doing is sending that to the front on drums which is not needed. the part is not expensive so use the correct one
mbgmike is offline   Reply With Quote
Old 07-24-2011, 12:25 PM   #9
mbgmike
abs will not matter at all.but you will need to go to the correct prop valve
