Old 07-24-2011, 10:43 AM   #1
FMJ_Blazer
Custom dash bezel
Have a 71 blazer and trying to install after market stewart warner gauges. I temporarily built a wooden bezel with cut outs behind it for the headlight and wiper bulges. Bought a Docs Custom aluminum billet bezel, but it doesn't fit just right. The mounting holes match, but the headlight and wiper holes don't and the cut outs behind wiper and headlight aren't shaped for the stock dash bulges. Any suggestions?
FMJ_Blazer is offline   Reply With Quote
Old 07-24-2011, 03:46 PM   #2
Yukon Jack
Yukon Jack's Avatar
Re: Custom dash bezel
I just used my stock bezel after cleaning it up and painting it.
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 07-24-2011, 07:28 PM   #3
FMJ_Blazer
Thanks Yukon Jack. I have already invested in gauges where the speedo and tack are smaller than stock (3 3/8). I found a dash panel at customdash.com. A little pricing but still cheaper than others and if fits nicely...maybe well worth it.
Old 07-24-2011, 09:02 PM   #4
71Rat
ran out of money
71Rat's Avatar
ive used a glove box door panel and welded studs on and put nuts from the backside. made it how i wanted my guages.
and yes i know the tach isnt level, i did this so i knew straight up was time to shift
Modify everything, leave nothing alone!~
71Rat is offline   Reply With Quote
Old 07-24-2011, 09:03 PM   #5
71Rat
ran out of money
71Rat's Avatar
ohh and if you do this the glove box door is 2 layers, you have to be careful and trim off the back panel so its only 1 layer thick. also need to weld up the button/lock hole
Old 07-24-2011, 11:06 PM   #6
red71cheyenne
Back in the sticks
red71cheyenne's Avatar
If you are going to use wood, you have to router out some wood to clear the dimples on the dash. Here's one of mine.
1971 Cheyenne C-10 w/700R4 and Tuned Port Injection
1969 K5 Blazer w/Tuned Port
2010 2SS/RS Flaming Orange Camaro
2011 K1500 Suburban
2014 K1500 Pickup
2008 Nissan Altima? The wifes' hoopty
red71cheyenne is offline   Reply With Quote
Old 07-24-2011, 11:37 PM   #7
JOHNORO
oldschoolblazer@yahoo.com
JOHNORO's Avatar
see if this helps...
http://67-72chevytrucks.com/vboard/s...d.php?t=457264
JOHNORO is offline   Reply With Quote
