So,, what else you got???
![]() Join Date: May 2010
Crossmember question???
OK guys. Still fighting the header clearance issues with our big block 68. My ONLY issue now is on the passenger side. The crossmember just behind the engine, not the transmission cross, the one just behind the engine. There is nothing mounted to it. Do I really need this crossmember? Not wanting to sound stupid but have seen several pics on here of trucks that don't seem to have this crossmember.. Any ideas would be appreciated. Thanks, Fred.
Member #1049
Re: Crossmember question???
That crossmember was for manual transmission trucks, they used a belhousing mount, if you have an automatic trans with the crossmember at the back if it you do not need the one you are referring too.
Thanks. That is what we thought, just wanted some more opinions. Yes, the truck was a 3 on the tree. Thanks again, Fred.
Sorry for the Hijack, but this may REALLY help me out. If I have converted from manual to a th350 auto this x member can go? It is in the way of my floor shifter linkage and I have been laying on my back for days trying to figure it out? If it can be cut out without hurting the safety of the truck my life has just gotten good again!
1967 GMC 3/4 ton Fleetside 350 ci Chevy I'd rather do it myself and spend the extra 500 dollars |
Project Junkie! Fishing Poor!!
![]() Join Date: Dec 1999
Yes it can go. WES
On-line catolog Classic Heartbeat Pickup Parts WEHEPP@comcast.net Call us Toll Free (888) 338-2502 Like Us on Facebook No appointment necessary. 72 BB Chevy Custom Deluxe / Custom Camper 67 I-6 (Soon to be 5.7 LS1) Panel 68 BB Chevy Short Bed 72 6.0 LQ9 Short Bed Chevy 4X4 Olympia's fastest growing truck parts supplier. Olympia's home for Wayward Chevys |
Like a Rock!
Mine has this also. What's the best/easiest way to remove????
69 LWB Runs great - work in progress Mess with me and you mess with the whole trailer park! ![]() |
I am thinking about taking an air hammer to the rivets.
![]() Join Date: Mar 2003
Yeah, the air chisel will work but not on the top rivets very well. I have in the past cut the member flush with the rails and left that small part still riveted to the frame. Then I smoothed it out with a grinder and sander. Sawzall works well also
x2. Then remove it later if the drivetrain is ever out for service. Much easier that way....
Sweet! Those rivets are a bear, but I harbor such animosity towards that X member I look forward to hacking it like an axe murderer!
Took the torch to it.. Crossmember is gone, headers are in... Now I can get back to working on the truck.
