Old 07-26-2011, 03:19 PM   #1
faribran
wheels making contact with lower A-Arm
i recently put front drop (truck)spindles on my 67. the rotors have been set up for 5 on 4 and 3/4 lugs.... i put some transam wheels(16in) and tires on it..
they do fine except for when i turn sharp.... i have trimmed the lower a-arm a bit... but they still make some contact..... i was wondering if anyone else has done this... maybe suggestions on what wheels might work and clear this.
input please
thanks
faribran is offline   Reply With Quote
Old 07-26-2011, 06:43 PM   #2
Lee H
Lee H's Avatar
Re: wheels making contact with lower A-Arm
Most drop spindles have a threaded hole to place a grade 8 bolt in to make a stop. That's what I have done. Grade 8 bolt, jamb nut and lock washer.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner.
1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components.
My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703
Lee H is offline   Reply With Quote
Old 07-26-2011, 07:36 PM   #3
SCOTI
SCOTI's Avatar
I've yet to see a C10-30 drop spindle w/a threaded bung to use for an adjustable steering stop. What brand specifically?
Wheels w/more than 4" of back-spacing will require a moderate to significant amount of trimming. Those 16" T/A wheels likely fall into that category. I had 18x8" wheels w/5.25"bs & trimmed the lip all the way back to about 1" from the shock mount.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 07-26-2011, 08:29 PM   #4
faribran
thanks for the input guys...
Old 07-26-2011, 08:30 PM   #5
faribran
i will check out the hole for the stop nut
