Non accessory to accessory?
I would like to change ignition switch with an accessory side....can this be done without too much hassle? My 68 doesnt have an accessory select on it. Everything else is stock. I think it would require a new switch and wiring ( I'm weak on wiring....) Any help will be appreciated.
Grandpa in the rustmobile...
Re: Non accessory to accessory?
My 68 has acc position....
is yours the 'small' 67 ignition possibly not having acc?
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
I've read from Longhorn man and Locdoc that 67's and some 68's didn't have accessory on the switch. I've also heard that its as easy as switching the wire from the ignition side to the accessory side once the switch has been changed (with the switch change giving the ability to turn the key in that direction, accessory isolates power to fan, radio etc... and the ignition powers everything) Just wondering if this is correct. Any links that touch on this mod?
My 68 has no acc, its an early one. also has no dimple for power steering.
I know this is not an answer your question, but i would also like to know. |
i tried an accessory ignition switch in my 67 gmc and the accessory did not power anything. I did not persue it any further so not sure what the solution would be. Could be as simpe as changing a wire position behind the switch but am unsure.
my 68 is early too..good luck! locdoc is smart he'll chime in soon
#7 | |
Name: Les ---------------------- Couple 80s Couple 70s One 68 ![]() |
Maxx, what is your assembly number? Just wondering....mine has a dimple and its, I think 130,xxx something. I'll have to check again.
Oldblue, ya them guys are! LocDoc......WHERE ARE YOU?!?! ![]() |
It must be more common to not have. I have 3 '68's (well, 2 trucks and a wiring harness
'68 Panel Project Boogie Chillin' '68 C-10 Ol' Green |
#10 | |
The ACC is far left about 1030 position, right?
Yea something like that, turn to the left of the off position.
