Old 07-28-2011, 03:21 PM   #1
k1rodeoboater
Hood spring removal
How hard is it to remove the hood springs? I have new inner fenders I kind of want to install, but the hood springs are the only reason I haven't done it yet. Any tips/tricks would be appreciated
1966 C10 Long step build on a budget http://67-72chevytrucks.com/vboard/s...d.php?t=445201
no garage, no shop, limited storage space and tools....no problem.
k1rodeoboater is offline   Reply With Quote
Old 07-28-2011, 03:29 PM   #2
chad64chevy
chad64chevy's Avatar
Re: Hood spring removal
A lil trick i did to remove them was, theres three bolts each side and start with the bolt in the front of the hinge the then the middle then loosen the back one and it will pivot down! it will take the the pressure off of the spring, and then you can take the spring off! do the reverse to put back on!
chad64chevy is offline   Reply With Quote
Old 07-28-2011, 06:33 PM   #3
chad64chevy
i take that back theres only two bolts and it pivots backwards, remove the bolt above the spring, the loosen the back bolt! i wasn't looking at the picture before i said anything! putting it back on in reverse, put the back bolt in then the spring then push down in on the front of the hinge to put the front bolt in!! sorry about that didn't mean to mislead you any!!
Old 07-28-2011, 06:42 PM   #4
markeb01
Senior Enthusiast
markeb01's Avatar
Here’s an earlier thread with a variety of opinions. I’ve done them both ways. The latest method was to eliminate any possible chipping or scratching, which can also be avoided with the rotating method if done carefully enough.
http://67-72chevytrucks.com/vboard/s...ht=hood+spring
Old 07-28-2011, 08:28 PM   #5
protrash64
Resistance is Futile
protrash64's Avatar
I grab them with channel locks and pull hard.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash
64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban
66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852
STRENGTH/DETERMINATION/MERCILESS/FOREVER
.......posted via stationary device
protrash64 is offline   Reply With Quote
Old 07-28-2011, 11:49 PM   #6
johan 1
put a rope trough the hook and pull.
johan 1 is offline   Reply With Quote
