Old 07-27-2011, 09:14 PM   #401
plummen
Re: post your 67-72 4x4
Lets see if i can get this to work.
Bottem picture is from when i first got started,but you get the idea.im still sorting out the cab mounts so i can get it sitting square then i can get to work on new floors ,cab corners and rockers.........
Then i can pull the cab back off and have it stripped at the blaster.
the frame is raised under rear of cab on newer frame to clear gas tanks im thinking which complicates things a little,Icould have just put the springs under the 69 frame i guess but i was too lazy to cut off all of those real steel rivets between the 2 frames!
Once i get the body back off ill get started on my dana 60 front end and 14 bolt floater rearend swap,Im thinking it will look pretty cool with a set of eagle alloy bud wheels all the way around and a flatbed with body repainted origional colors.
any suggestions or complaints? yeah i know the yellow driveshaft came with the chassis,it will be gone soon! hahaha
plummen is offline   Reply With Quote
Old 07-27-2011, 09:22 PM   #402
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Cool project. It appears you are using a 80's 4x4 chassis for your truck?
Ryan
1969 Chevy milk truck
Old 07-27-2011, 09:42 PM   #403
plummen
Yep,the c-clip rear axle kind of gives it away but the price was right!
I tried finding a k30 with a flat frame to use but all the ones i looked at were pretty well hammered so im just going to graft 1 ton axles/suspension on to this frame and some extra cross members.
Id like to stick a cummins in this thing to really screw with peoples heads like one of your projects,but i like traveling a lot of back highways and diesel fuel can be tough to find in some ares
Old 07-28-2011, 02:23 AM   #404
68 TT
Still plays with trucks
68 TT's Avatar
Going with a flat bed you don't need to mess with the wheel base being 4" different but you can pull 16" from the frame behind the cab and relocate it under the cab to push the frame transition far enough back to clear the rear cab brace & sheet metal seam of the body without having to put a substantial body lift on it.
The cab mount issue is best fixed by grinding off the 20 rivets holding on a set of 67-72 mount brackets and fitting them to the 73-87 truck frame. With a new set of cab mounts you can bolt them to the 67-72 brackets, bolt the brackets & mounts to the cab and use the brackets to square the cab to the frame. The square body cab mount brackets don't line up well enough to use them.
The core support & front bumper are the fun part as they are in a different location and need some creativity. I am cutting the frame horns off some scrap 67-72 frame rails and will graft them into the square body frame as needed.
69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been https://67-72chevytrucks.com/vboard/...d.php?t=484426
69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc
68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E
68 TT is offline   Reply With Quote
Old 07-28-2011, 01:44 PM   #405
plummen
Im using the front cab mounts from the 69 frame on the newer chassis(12 rivets )i bolted them on with 1/2" grade 8 bolts,so i dont think theyll be an issue anyway.
The biggest issue so far is the hump in the frame,ive been under there scratching my head thinking of best way to remove it so i dont have 12" of clearance between my front fenders and tires!
The weird part is theres only about 2 1/2" of clearance between the front wheel wells and top of frame rail.
Any way Ill either take a section of the 69 frame to put in place of hump in newer frame or ill have a section of frame rail custom made to weld in there and "double frame " the outside of that section like a dump truck frame.
Good thing i used to work at a steel foundry about a mile from here,ive still got access to lots of things the average person would kill for
Old 07-28-2011, 01:57 PM   #406
plummen
I measured the core support location between the 2 frames,the one on the 69 appears to be back right around 1 1/2" from the newer frame,of course its mounted to the top of the front spring perch to help support it,more rivets!
Has anybody used a newer rear axle out of a chevy 2500hd truck under one of these?I know they have c-clip style axles in them but they come with big ol disc brakes on back already.
I helped a friend swap out his shelled out 2001 1/2t rearend to a 2500 hd rearend which was pretty simple other than a u-joint swap in his case.
The yard we bought his from has 2-3 2500hd's sitting out there there with posi rearends for $350 including rotors/calipers ,just kicking the idea around to see if its any cheaper than doing a disc brake swap on a 14 bolt rearend .
Old 07-29-2011, 01:06 AM   #407
jerad121
hey guys im new here just wanted to post a few pics of my rig and say hey
jerad121 is offline   Reply With Quote
Old 07-29-2011, 02:40 AM   #408
plummen
Thats a stout looking old chevy youve got there!
Old 07-29-2011, 02:48 AM   #409
jerad121
thanks man. im on the look out for a 60 front and a 14 bolt rear right now. and still trying to decide what route i wanna go motor wise. but its a fun project
Old 07-29-2011, 03:49 AM   #410
plummen
The 14 bolts are pretty easy to come by around here anyway,the last 2 dana 60s ive come across were for dually trucks
Old 07-29-2011, 05:02 AM   #411
67chev_4x4
67chev_4x4's Avatar
Originally Posted by Outlaw_71 View Post
Here is mine-
nice truck man that is what i dream myn will look like
67chev_4x4 is offline   Reply With Quote
Old 07-29-2011, 05:05 AM   #412
67chev_4x4
67chev_4x4's Avatar
new here also just wanted to show a start of my long project. 67 c10 body on a 70s frame 5 speed with a 87 350
Old 07-29-2011, 05:07 AM   #413
plummen
you guys keep raising the bar on the rest of us!
Old 07-29-2011, 05:25 AM   #414
67chev_4x4
67chev_4x4's Avatar
i am looking to make it into a show/sled pull truck just have to get the parts
Old 07-29-2011, 10:39 PM   #415
68 TT
68 TT's Avatar
What did you do to the frame to make the cab fit with the bed mounted on the rails?
Old 07-30-2011, 12:47 AM   #416
67chev_4x4
67chev_4x4's Avatar
put some lift bocks on so everything would sit rails right. if you look at the wheel wells you can see the gap it suxs but im trying to find a way to close it up but make it look right
Old 07-30-2011, 02:38 PM   #417
68 TT
68 TT's Avatar
I'm working on the same problem. I will let you know what I come up with when I get back to that project.
Rebuilding the new axle assemblies for my 78 K20 right now so the 5.13 geared ones can go to their new owner. Once that is done I will be back on the 67/69 4x4 conversion project.
Old 07-30-2011, 08:29 PM   #418
plummen
ive got a roll off that black plastic skirting stuff that goes in between the body/frame for a 2" body lift kit to hide the gap.
free to good home if somebody can use it,new still in box
Old 07-30-2011, 09:12 PM   #419
Jackedup67
I Dig the hell outta that truck jerad121. Heres Mine
Jackedup67 is offline   Reply With Quote
Old 07-30-2011, 11:09 PM   #420
67chev_4x4
67chev_4x4's Avatar
im going to try this kit out that im getting off a guy and i will let you know how it works
Old 08-04-2011, 01:58 PM   #421
jerad121
Thanks man it's a work in progress. Yours is pretty bad too
Old 08-04-2011, 06:12 PM   #422
Jackedup67
Hey, Thanks Man , Much Appreciated!
Old 08-10-2011, 10:56 AM   #423
rjsdad
rjsdad's Avatar
Awesome looking truck guy! What size lift do you have on that? I bet you get a lot of looks in So Cal.
Jeff
rjsdad is offline   Reply With Quote
Old 08-10-2011, 12:07 PM   #424
jerad121
Thanks man. I'm not really sure on the lift size but it's big enough to clear 38.5" boggers no problem. Yeah I get alot of looks in so cal I guess it's cause I don't drive a lifted truck on 22s with a low pro mud tire haha.
Old 08-10-2011, 07:58 PM   #425
rjsdad
rjsdad's Avatar
Yeah, it's hard to beat those Excursions and F350's with 12 inches of lift riding on 24" wheels and the only off roading they do is driving down vendors row in Glamis.
