What does this wire go to?
I was under the hood, looking for the wire to go to my temperature sensor as the PO did a hack job with the wiring and didn't get any of the gauges working.
Anyways, I think I found the temperature wire, but I'm not sure. It's got 2 plugs and it's green. Thanks
K10 Scottsdale305 ci | TH350 | NP208 | 60k miles Last edited by sethv; 07-28-2011 at 03:35 PM. |
resident wrencher
Re: What does this wire go to?
Thats not it right color but wrong number of pluggs there should be one connector on a green wire
Alright, thanks. Does it have the same style plug on the end?
K10 Scottsdale305 ci | TH350 | NP208 | 60k miles |
resident wrencher
My work computer wont bring up the pic but if you re post it as an attachment it might the clip is kinda like a felmae spade connector but a tad different
Alright I updated the post.
resident wrencher
Do you have one of the other side there sould be like a slot it slides on the clip from the side not the end
resident wrencher
If it dose then its the rigth clip and size and color wire
78K & 79C Jimmys
the temp sensor comes with different male plugs
PO may have added the different type with wire rather then change it?
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 Last edited by motornut; 07-28-2011 at 05:56 PM. |
I had the same wire on my 81 inline 250. One end was connected to a sensor on the thermostat houseing and the other was to a sensor on the side of the head. Drivers side.
horn wire looks like that
| Bookmarks |
