Old 03-26-2011, 09:42 AM   #1
Q.8
Q.8's Avatar
does these headers fit my 66 c30?
hello guys
want to ask if these headers will fit my truck?
and for those try it be4,what u think about the quality ? does they work fine?
i want be sure its fit be4 i buy
thanks
guys,,,im overseas member..so please ,,respond me with easy english,coz its my second language....thanks
--c30 1966 frame off 5 years restoration ; Finished;
Chevy suburban 1958 restoration ( In progress )
85 c10 "back to original project <Finished> "
81 c10 "back to original ( later) "
85 c10 cattleman edition lifted ( finished)>
K1500 1989 full restoration ( soon )
S10 1991 in progress
Q.8 is offline   Reply With Quote
Old 03-26-2011, 09:47 AM   #2
Rich 5150 69
Rich 5150 69's Avatar
Re: does these headers fit my 66 c30?
Yes they will, but if they are chrome they will turn blue and rust eventually, you`re better off getting high temp coated hedders as they will retain their appearance longer, price wise sinse shipping is factor for your you`re better off.
`64 C10 vortec 350/350/373 posi
`69 RS/SS 350/350/308
`37 Ford 406/350/324 traclock
`68 Dart 370/904/323 suregrip
Rich 5150 69 is offline   Reply With Quote
Old 03-26-2011, 10:08 AM   #3
Q.8
Q.8's Avatar
thanks for help
there r many brands but they are cost to much,and shipping for kuwait is killing me.
i have other idea,,,i can use same headers but black coated and use this chrome cover..i think it will be nice..but any one have pics of them instaled? just want to see how they look under the hood.. again thanks
Old 03-27-2011, 04:54 AM   #4
Q.8
Q.8's Avatar
any 1?
Old 03-27-2011, 09:25 AM   #5
neto
neto's Avatar
I haven't seen any headers with those kind of covers before.
neto is offline   Reply With Quote
Old 07-27-2011, 11:12 PM   #6
Q.8
Q.8's Avatar
im working now in instaling the v8 sbc..these headers not fit.it touch the engine mounts.
i pay 1500$ for chrome parts,and many of it not fit such as these headers,oil pan ,alternator brackets and maybe other parts still in the boxes.
realy i lose money and time.and will stop to buy other parts and spend more money.
now i know what pain in the ass mean.!!
Old 07-27-2011, 11:51 PM   #7
Captainfab
60-66 Nut
Sorry to hear of your issues. I somehow missed this thread before. I would have told you no they will not fit. Can you cut the motor mount for clearance?
Old 07-28-2011, 12:09 AM   #8
Q.8
Q.8's Avatar
nope i can not.its need more clearance,and you know when the car run the engine will move a little when you hit the gas pedal.
i found other style i think it will fit,they said in the ad "This is a set of brand new small block Chevy heavy duty truck headers with a chrome finish. They fit 1988-1995 small block Chevy engines using standard exhaust patterns such as 265, 283, 302, 305, 327, 350, 383, 400, etc, and GMC pickups such as 1500, 2500, 3500"
what you think captin? or any one instaled them? by the way, have manual trans from 1992 truck
Old 07-28-2011, 12:22 AM   #9
Captainfab
60-66 Nut
I do not know for certain, but I doubt those will fit either. The 1988-95 trucks have more room between the engine and the frame. Member Alan's Classic tried a set of 1988-'98 headers on his truck and they did not fit. You might look at his build thread to see what he used that fit. Can you use long tube headers?
Old 07-28-2011, 12:41 PM   #10
bama63
bama63's Avatar
this is what i used and they fit perfectly.
Hedman 69640 - Hedman Hedders Standard-Duty Uncoated Headers Details
Jeep engine swap headers
# 1967-91 CHEVROLET,GMC C20, C30, C25/C2500, C35/C3500, C2500, C3500, R20, R30, R2500, R3500, V20, V30, V2500, V3500 PICKUP 283-400ci; 2WD Without smog injection or injection heads.
# Will fit with angle plug heads (Chevy aluminum only).
# Shortie style hedder. Maximum ground clearance.
# Elite replacement gasket #27520.
# Not legal for sale or use in California on pollution controlled motor vehicles.
# Under chassis exit.
# Modification to stock exhaust required to retain catalytic converter.
# Not applicable or intended for street or highway use. Legal only for racing vehicles which may never be used upon a highway, check footnotes also.
File Type: txt headman hedders.txt (797 Bytes, 38 views)
Due to financial constraints, the light at the end of the tunnel will be shut off until further notice
bama63 is offline   Reply With Quote
Old 07-28-2011, 01:56 PM   #11
wildearp
wildearp's Avatar
It is best to get the flange further away from the exhaust ports. If you run it hard, the flange on block huggers will usually warp and never seal again, regardless of the brand or quality of the block huggers. In fact, aluminum flange seals will melt on them. Aluminum flange seals will not usually melt on full length headers.
I will never run block huggers again.
wildearp is offline   Reply With Quote
Old 07-29-2011, 01:13 AM   #12
Captainfab
60-66 Nut
Here are a pair of headers that are designed to fit the '60-'66 trucks. These will work with a manual trans.
http://www.summitracing.com/parts/HED-69260/
Here is a pair of headers that are designed for newer trucks but will also fit the '63-'66 trucks. These will work with a manual trans with slight modification to the clutch bellcrank
http://www.summitracing.com/parts/HED-69090/
These two headers are also available in the Elite series as part numbers 69268 and 69890
Old 07-29-2011, 11:26 PM   #13
Q.8
Q.8's Avatar
Thanks guys for help.capitan,i think the short one will fit better.
Now im thinking to make custom one,i will cut the base of the headers and lookin for other pipes and weld it to fit my engine mounts.
Or i think i will buy the other one attached up.thanks bama36.thanks wildearp
