Cruzin
Spindle/brake ?
Ok i'm working on my wife's 67 that has been converted to five lug. I'm pretty sure it's the 73 later parts. I noticed this morning as i'm tearing the passenger side down for new ball joints that the caliper has a bolt with a nut on it not the usual caliper bolt. The driver side was correct but the passenger side doesn't have the threads in the spindle for the bolt. So my ? is did they drill the threads out of the spindle or was some like this? I'm starting to get
Lime Wife's 67https://www.google.com/url?sa=t&rct=...wZEMODaS2d94u8 Back to the Fifties 59 https://www.google.com/url?sa=t&rct=...NAeStpydfrcj_U Proverbs 3:5,6 "Thanks to the Interstate Highway System, it is now possible to travel across the country from coast to coast without seeing anything."Charles Kuralt In memory of our first baby daughter, daddy and mommy love you. Danica Grace 6/26/14
Re: Spindle/brake ?
calling doctor hack..
someone cross threaded it at one point in it's life, and instead of heli coil they nut and bolt.. if they didn't drill out the threaded hole to large you can heli coil the hole and get a new calp bolt |
Cruzin
Re: Spindle/brake ?
thanks, i will add the brakes on that side was locked up couldn't turn the tire hardly at all. Maybe a result of the caliper not being able to float? I think i have a spare spindle somewhere off a 86 model or will try the helicoil (those are a great invention!)
