Old 06-26-2011, 09:23 PM   #26
70custom20
70custom20's Avatar
Re: D60 Front Brake Upgrade
Originally Posted by mcmlxix View Post
The 3/8 bracket with the Dodge rotor only has a few thousandths of interference.....
I havent figured out the rest of the braking system yet. I will probably need an adjustable proportioning valve to tune rear bias. The MC only has two ports so I will need a distribution block or a T block for the front. I'm not sure what would have been used in the 2005 GMC from the facotry. Fisrst step, and the reason for this thread, was to see if I can get the parts mounted to the D60. I hope to see the brackets on Monday and have it machined this week coming up....
For what it's worth, I have a drag car with Strange engineering racing discs on all four corners, and I am not using a proportioning valve at all. The car has no issues stopping from 136+ MPH trap speeds. I don't know if it would be the same for all vehicles though.
Keep up the good work, as I am following this thread closely. I really am thinking just like you as far as capitalizing on modern engineering to upgrade the braking system. My truck is a 70 3/4 ton D60 front, 14 bolt rear.
70custom20 is offline   Reply With Quote
Old 06-26-2011, 09:58 PM   #27
ghettoluxury
ghettoluxury's Avatar
cant wait to see your brackets
1949 Five Window, 1973 Step Side, 2000 Z71
ghettoluxury is offline   Reply With Quote
Old 07-02-2011, 06:13 PM   #28
70custom20
70custom20's Avatar
What did the factory caliper brackets for the dodge look like? Any chance that they could have been modified?
Old 07-03-2011, 06:17 AM   #29
mcmlxix
Collector of Projects
mcmlxix's Avatar
I am using the Dodge calipers... unmodified... check out post #18 for pics.. you can see the MOPAR logo on the caliper....
Rich
1972 K5 Blazer CST Click HERE
Old 07-03-2011, 09:05 AM   #30
70custom20
70custom20's Avatar
Caliper mounting brackets. Could the factory caliper mounting brackets have been used, modified? Just wondering.
Old 07-03-2011, 07:30 PM   #31
mcmlxix
mcmlxix's Avatar
I think there is a confusion on th ebrackets. The caliper and abutment (bracket the caliper slides on) is being mounted to a custom bracket that fits the Dana 60... without my bracket there was no place to attach the abutment for the caliper to slide on.....
The goal was to be able to use off the shelf parts without needing to modify them... I will be able to go to any parts store or dealer and buy calipers rotors or pads and put them on. This helps if you travel and break something...
Rich
Old 07-03-2011, 09:56 PM   #32
70custom20
70custom20's Avatar
Rich, yes, I was unaware of what was meant by abutment. Keep up the good work, I'm really anxious to see how this all turns out. Thanks, Kurt
Old 07-04-2011, 02:22 AM   #33
mcmlxix
mcmlxix's Avatar
Ok. Here is the teaser shot of the brackets, cut out of sheet metal on a waterjet, used to test alignment of components... The sheet metal will be replaced with 3/8" plate (This may change to 5/16" plate to eliminate the need of some machine work) The spacer is 1.5" x .25" DOM and will be TIG welded when complete and ground flush. I may cut them down prior to welding to eliminated the extra step of grinding flush.
Rich
Old 07-04-2011, 05:13 PM   #34
70custom20
70custom20's Avatar
Cool, Rich. It's good to watch the progress your making. Sorry if I'm asking too many questions, but I was wondering how the hydroboost from the 05 GMC was going to work with the redhead steering box you put on the Blazer. The hydroboost I would assume is metric fittings, while the steering box, and maybe the power steering pump are probably standard threads, no?? Thanks again, Kurt
Old 07-04-2011, 07:35 PM   #35
mcmlxix
mcmlxix's Avatar
You are correct. I will probably end up with -AN adapters on all components, then have hoses made to fit from a local place. Still not sure yet, havent looked into the hydro side of the euqation...
Rich
Old 07-11-2011, 11:58 AM   #36
68 TT
Still plays with trucks
68 TT's Avatar
Looks great.
Leave a 1/4" of the DOM tube sticking up above the brackets and do a fillet weld between it and the plate brackets. Far stronger than an edge weld you would have if the DOM tube was flush with the brackets. Last thing you want is that thing cracking a weld and parts coming loose when you need them most.
69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been https://67-72chevytrucks.com/vboard/...d.php?t=484426
69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc
68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E
68 TT is offline   Reply With Quote
Old 07-12-2011, 05:12 AM   #37
mcmlxix
mcmlxix's Avatar
On the rotor side I won't have the 1/4... It’s such a tight tolerance that I will only have a few thousandths between the rotor and brackets. I’m not a welder but the idea was to weld the inside edge 360* where the DOM meets each bracket. I’ll leave the fillet to the fish ….
I flexed my MS Paint photo-chop skills... the RED in the pic below is where it will be welded... the other side is the same but cant be seen at this angle...
Rich
Old 07-12-2011, 11:59 AM   #38
68 TT
68 TT's Avatar
That will work too as long as you can get the TIG or MIG welder torch in there at the proper angle to weld it right. I would weld the rotor side part to the DOM first then put the spindle side bracket in place and weld it from the spindle side where it is easily accessible. This way you have full access to the weld area to do a good quality weld all the way around the DOM tube.
Old 07-24-2011, 08:55 PM   #39
mcmlxix
mcmlxix's Avatar
Here are the brackets, cut on the waterjet, out of 5/16" plate. No clearance issues and everything lines up great. Still need the RH caliper for alignment then they can be TIG'd... I was thinking of making a jig to hold the pieces to be welded....
Passenger side ...
Driver side...
Rich
Old 07-24-2011, 11:30 PM   #40
68 TT
68 TT's Avatar
The parts look great and look to fit well too.
I love how nice things look when they come off the water jet. I wish I had one.
Old 07-25-2011, 01:32 AM   #41
Maxxd07
Maxxd07's Avatar
Wow that is some great work!
Couple 80s
Couple 70s
One 68
Maxxd07 is offline   Reply With Quote
Old 07-25-2011, 03:00 AM   #42
mcmlxix
mcmlxix's Avatar
Thanks. The waterjet makes it look like I actually know what I'm doing...
Here is a link to the dorman catalog... http://www.dormanproducts.com/catalog/2006_hardware.htm
I'm going to need longer wheel studs... which seems to be more difficult then originally expected. The hole in the hub for the stud is larger then most of the options in 9/16-18 and if you upgrade to 5/8-?, they dont seem to offer a 60* lugnut for aluminum rims... just 90* seat for "other" rims ...
The factory studs are 2.5" and I was looking for 3.75" or greater....
Rich
Old 07-25-2011, 10:55 AM   #43
ghettoluxury
looks killer
Old 07-25-2011, 12:45 PM   #44
68 TT
68 TT's Avatar
What about going with the newer 14mm studs? Does that give you more options that might work?
Converting the rear end to match would be kind of necessary if you used 14mm up front and wanted to run a matching set of wheel locks or like mine a full set of 32 Gorilla wheel locks.
Old 07-25-2011, 12:55 PM   #45
68 TT
68 TT's Avatar
What knurl diameter is in the hub?
Old 07-25-2011, 08:51 PM   #46
mcmlxix
mcmlxix's Avatar
The stock knurl diameter is listed as .65 and I measured all of my studs that came out of the hub with a range of .642 to .648
The 14mm was a thought because my rear (the one I might sell, long story) has the 14mm - 1.5 but none of the dimensions work...
They make a longer stud in 9/16 but its only 3-9/32" and I wanted at least 3-3/4" ... also, the knurl is .677 so I would have to drill... (610-303 dorman)
I did find that Gorilla makes a lug nut for the 5/8 with the correct 60 degree seat so I think I'm going to upgrade to a 5/8 stud.. its knurl is .657 so I probably wont need to drill.... (610-418 dorman)
Rich
Old 07-27-2011, 12:13 AM   #47
68 TT
68 TT's Avatar
You will probably need a press to get them in with the .657" knurl but it should work.
Old 07-30-2011, 09:02 PM   #48
plummen
Not really.... I got a spare factory bracket two days ago and started to cut and modify. It looks like there are some interference issues. I had exchanged the Dodge rotor for a Chevy rotor because the offset was too deep to use with the factory bracket. I have since picked up another Dodge rotor so I have both to check fitment. I have also ordered a 2009 Dodge 2500/3500 caliper. The Chevy caliper does not fit the Dodge rotor because of overall diameter.... Right now I need some one to waterjet or CNC cut a 3/8" straight bracket...
Here is the factory bracket with one of the ears cut off...
Here is the Chevy rotor and caliper bracket ....
I did pick up a Astro/Safari Hydroboost unit as well as one from a 2005 GMC 3500 truck. I am glad to report that they are interchangable between the two as far as mounting goes. One difference is the Astro has a single keyway where the newer unit has dual keyways. The Astro also has a smaller diameter hole for the master cylinder compared to the GMC 3500. The Astro HB shold support the late 70's Corvette MC for disc/disc brakes. I am using the 05 hydroboost w/ MC and have the Astro/Safari unit in the For Sale section. My goal was to establish if CaptainFab's brackets will work on the newer hydra boost and it does....
Here is a link to the CaptainFab bracket... CLICK HERE
here is a pic of the Astro/Safari hydroboost
if you still need the brackets made ive got a guy about an hour from here that has cnc plasma cutter im taking some parts to next week to have made
plummen is offline   Reply With Quote
Old 07-31-2011, 12:43 AM   #49
mcmlxix
mcmlxix's Avatar
Thanks but I already got the brackets cut locally...
Rich
Old 07-31-2011, 12:45 AM   #50
mcmlxix
mcmlxix's Avatar
On Thursday I dropped off the brackets at the welder to TIG the spacers in place. Hope to pick them up next Thursday. Still need to grind the spindle flange to clear the caliper abutment. Got the RH caliper from the brown truck on Friday. I will probably disassemble and powder coat them red. The RH hub was dropped off to be machined and I left them with one 5/8 stud to test fit (press in.) I also ordered some lug nuts off eBay...
Rich
calipers, d60, hydroboost
