Old 07-29-2011, 08:19 PM   #1
Chevys10dr
Chevys10dr's Avatar
Volt Meter not working
Hey guys,
Pretty new to this stuff, I just got a 71 Cheyenne SWB, noticed the meter isn't working. Is the any wires that connect to the meter or is it ran by the printed circut board.
Chevys10dr is offline   Reply With Quote
Old 07-29-2011, 08:27 PM   #2
Shyguy
Junior Member
Shyguy's Avatar
Re: Volt Meter not working
The stock meter is an ammeter and usually the two small fuses go bad. They are located on each side of the radiator.
Most people hook up a after market voltmeter.
'67 Chevy C-20 short stepper - build complete, 454/SM-465.
'75 C-30 Single Cab DRW-350 small block/NP-435.
'77 GMC-6500 Dump Truck, 427 Tall Deck.
'92 GMC K-3500 Duallie, 454/4L80E.
Shyguy is offline   Reply With Quote
Old 07-29-2011, 09:19 PM   #3
71meangreenc10
Its a Truck Thing......
71meangreenc10's Avatar
Yeah,
look for the small black fuse holders, they have small glass fuses in them, always go bad.
Smitty
71 C10 283/3SPD Full Resto
71 GMC 1500 Sierra Grande http://67-72chevytrucks.com/vboard/s...d.php?t=518599
70 C10 Suburban Former military GSA truck.
72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378
72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110
68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head
71 C30 Wrecker
71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck
68 GMC Long Stepside. They keep following me home
71 C20 Longhorn/Ole Yellor
69 C30 Former Motor Home, Flat Bed time
71meangreenc10 is offline   Reply With Quote
Old 07-30-2011, 12:28 AM   #4
chevytruckluver
Eat, Sleep, Drive a Chevy
chevytruckluver's Avatar
Welcome from Texas. What you see in the picture is correct there are no wires connected, yes it does use the printed circuit board. Check those fuses, even if they are good and all the other wiring is ok an amp meter wont move very much. If you have access to a DC volt meter check voltage across the battery terminals while the engine is running above idle speed you should see 14 volts. If you dont have access to a meter most auto shops and many parts stores will check for free
Good luck
Trey
Silence may be Golden, but Duct Tape is Silver!
72 Short Step
57 "big window" short step
chevytruckluver is offline   Reply With Quote
Old 07-30-2011, 10:43 AM   #5
MagmaJct
MagmaJct's Avatar
Anyone know where to find the small fuses? I had to use standard length fuses and wrap electrical tape around them.
MagmaJct is offline   Reply With Quote
Old 07-30-2011, 11:09 AM   #6
Chevys10dr
Chevys10dr's Avatar
Thanks guys,
I looked for the fuses but no luck, there seems to be all new wiring in this truck. I have access to a to a volt meter and I will have to check that.
Thanks again.
Old 07-30-2011, 11:30 AM   #7
68gmsee
Active Member
68gmsee's Avatar
Another thing you can check after you make sure the alternator is putting out at least 13.5 (or slightly more) vdc is the ground straps.
If you don't know where they go do a search on ground or ground straps.
68gmsee is offline   Reply With Quote
Old 07-31-2011, 12:54 AM   #8
dmack91
dmack91's Avatar
I think they are SFE4 fuses, and I got them at a local auto parts store (most carry them).
The fuse holders don't look anything like any I have seen before. They are black and look more bulb-like, about 3/4" round and made of rubber.
They are right where the fender meets the radiator support.
68 Chev C20- son has it now
83 K20 - bought from son
70 C20 - in progress
dmack91 is offline   Reply With Quote
