Old 08-05-2003, 11:18 PM   #1
Nelson
Flat Seat spark plugs?
This might be a studip question, be what exactly are Flat seat spark plugs. Are those the R43 (13/16")? My 441 Heads are suppose to take flat head spark plugs, and I think the regular R44TS might be to long. Any help would be appreciated.
Nelson
1970 C10 350 Auto.
A/C not Working
Nelson is offline   Reply With Quote
Old 08-05-2003, 11:45 PM   #2
Nelson
ttt
Nelson
1970 C10 350 Auto.
A/C not Working
Old 08-05-2003, 11:49 PM   #3
oldsub86
a bit of a guess here but my recollection is that most newer models have spark plugs that have a tapered seat on them just above the threads. Older style heads had plugs with a flat seat and the washers that compressed a bit the first time the plugs were tightened in.
1968 Chevy - 292 with a powerglide
oldsub86 is offline   Reply With Quote
Old 08-06-2003, 02:15 AM   #4
biddaboy
biddaboy's Avatar
I use R-44 in all my old style heads with the large plugs and dont forget the washers. biddaboy
biddaboy is offline   Reply With Quote
Old 08-06-2003, 03:08 AM   #5
dmec
dmec's Avatar
any ac plug with a t in it stands for tapered seat which does not require a gasket and will not seat properly in early heads. i havent been able to find r44 or r45 plugs. can find r45s. the s stands for extended tip which means the shell doesnt shroud the tip. so stay away from a plug with a t after the number but any number alone or with a s after the number will work.
dmec is offline   Reply With Quote
