Old 07-27-2011, 07:42 PM   #1
swierker
swierker's Avatar
question about removing a arm shaft nuts
Sorry if this is a simple question but this is my first time with a front suspension rebuild. What is the best way to remove the A arm shaft nuts (the ones at the ends)? The lowers look like they need over a 1 1/2" wench or socket to remove them and I don't have anything quite that big.
Is there tool from one of the auto parts store for loan that can be used for this? Or do I need to find a wrench or socket that big?
The A arms are from my 70 C10 and they have been removed from the truck.
Thanks in advance.
Dan
1970 Chevy LWB - 305/350
In Progress: 4/6 ECE drop, front discs, power brakes, Coys C5's.
swierker is offline   Reply With Quote
Old 07-31-2011, 01:16 PM   #2
Wrenchbender Ret
Re: question about removing a arm shaft nuts
You will have to buy a socket to fit it. Im not sure weather 1/2 in drive goes to that size. If not you will need a 3/4 drive socket & a reducer to use it on 1/2 in. drivers.
Wrenchbender Ret is offline   Reply With Quote
Old 07-31-2011, 02:16 PM   #3
SCOTI
SCOTI's Avatar
You don't have to buy that large of a socket.
A pipe wrench (in most house-hold toolboxes) will do the job. You might look around for a 'cheater' pipe to slip over the end of your wrench as sometimes they're a little stubborn.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 07-31-2011, 03:23 PM   #4
Shane
Shane's Avatar
I use an 18" crescent wrench ...
Shane is offline   Reply With Quote
Old 07-31-2011, 03:50 PM   #5
cdowns
cdowns's Avatar
big wrenches and sockets are good things to have to complete a tool set// my 1/2drive sockets go up thru 21/2 inches
Old 07-31-2011, 04:00 PM   #6
Mike Bradbury
Mike Bradbury's Avatar
f you plan on reusing the caps then I would invest in a socket for them, so that they do not get all galled up as you are removing them. Mine were on pretty tight from all the years of grease and dirt that had built up in the joint.
I'd rather attempt something great and fail.. than try something ordinary and succeed. Norman Vincent Peale
Project: Barn Raising http://67-72chevytrucks.com/vboard/s...d.php?t=414961
Project: 30 Be Low https://67-72chevytrucks.com/vboard/...d.php?t=830583
Mike Bradbury is offline   Reply With Quote
Old 07-31-2011, 09:25 PM   #7
SCOTI
SCOTI's Avatar
A couple trips around the edge w/quality masking tape prevents most galling. Worst case scenario needs a little bit of work w/a flat file when you're done.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
