Old 08-01-2011, 12:00 AM   #1
383Chevy
[><]Sofa King Dirty 4x4[><]
383Chevy's Avatar
What gears for towing
What gears are good for towing my buggy its like 2000lbs or less i have 33" tires and last time i towed i over heated bad so im switching to a 3-4 core radiator but i still think it needs different gearing
00' Chevy Silverado 1500 z71
33"s
3" lift
5-speed
Past trucks
85' Chevy C10 Step side
388 stroker
33" bfg a/t's
holley 670cfm
world product heads
14.80@92mph
92' S10/Tahoe sbc swap
383Chevy is offline   Reply With Quote
Old 08-01-2011, 12:07 AM   #2
thirdstreettito
Resident of Here
thirdstreettito's Avatar
Re: What gears for towing
What engine/trans/current gear ratio? What truck is it? The more info you give the better answer you get.
~Bradley~
2004 Black GTO LS2/T56 too much to list
Miss having a truck
thirdstreettito is offline   Reply With Quote
Old 08-01-2011, 12:14 AM   #3
383Chevy
383Chevy's Avatar
Engine-388 stroker
Trans-TH350
Gears-I think 3.23
Truck-85 chevy c-10 step side
Seems when i had 4.11 gears it towed better but i cant seem to find them cheap so maybe 3.73?
33"s
3" lift
5-speed
Past trucks
388 stroker
33" bfg a/t's
holley 670cfm
world product heads
14.80@92mph
Old 08-01-2011, 12:52 AM   #4
thirdstreettito
Resident of Here
I suggest 3:73 because you dont have OD. Get Yukon brand gears, better than stock and great quality.
~Bradley~
Miss having a truck
Old 08-01-2011, 02:43 AM   #5
VegasBruce
VegasBruce's Avatar
With the 33's 3.73 will run about 2530 RPM at 65 MPH and the 4.11's about 2780. However I would check out the cooling system first, make sure there is no other problems before swapping gears. It shouldn't overheat as it sits now, a 2000# trailer isn't a heavy load.
Bruce
73 Stepside, 74 Blazer, 75 1 Ton, 66 Barracuda and a 05 Electraglide DD
http://i56.photobucket.com/albums/g1...Rusti192-1.jpg
VegasBruce is offline   Reply With Quote
Old 08-01-2011, 03:01 AM   #6
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
Yea, I tow a popup camper with my Jimmy 4.3. Weight when load with gear is close 2000 lbs. The 3.42 gears do okay on the highway. 3.73 would be great overall gear.
Gerardo a.k.a. Mad Chemist
Silverado XST videos
Old 08-01-2011, 03:10 AM   #7
383Chevy
383Chevy's Avatar
Its prolly close to 3500-4000 with the buggy thats when i over heated but its my radiator im gettin a bigger one then will try it
33"s
3" lift
5-speed
Past trucks
388 stroker
33" bfg a/t's
holley 670cfm
world product heads
14.80@92mph
