Lucky Teter at the wheel
Re: ** YOUNG FRANKENSTEIN ** The truck Chevrolet should have built.
OK, looking better now. We'll see how the monster looks after a wet sanding with 400 grit. I'll be down to tiny spots to fill with glazing putty I'm pretty sure. Then prime again and block/wet sand with 600 grit.
Everything I read talks about how 400 grit scratches don't show in the final paint, but I beg to differ. I tried it on both the black truck and the green Denali and I could see the scratches in the right light. I also do not trust that if I wet sand/block with 400 grit and then go back over with the 600 grit that I will find and eliminate all the 400 scratches. When you are doing it you just cannot tell where you have been or not since it is already a sanded texture. That is why I will respray the primer and then go over it again, this time with the 600 grit. I use and 11 inch block with 8 by 11 sheets of wet or dry sandpaper cut in half wrapped on the block. If you hand sand this step you can end up with tiny ripples in the surface instead of mirror flat.
Drew YOUNG FRANKENSTEIN (Finished with MAJOR Surgery - IT'S ALIVE!!!) The Bride is currently under the knife!
#2 | |
Still Learning
#3 | |
Still plays with trucks
20 years ago the factory paint jobs weren't so hot so his repairs were on par with what was on the truck to begin with. Definitely not show car worthy but fine for a daily driver. Just to be safe I always use 600 to wet sand the final primer coat on my own projects.
69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been https://67-72chevytrucks.com/vboard/...d.php?t=484426 69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc 68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E |
#4 | ||||||||||||||||||
