07-30-2011, 12:24 PM | #1 |
E-Brake emergency brake help
I need help in figuring out how to get the parts I need for my son's 64 C10. I have the cables coming from the rear wheels and I have a handle. Both are pictured. What I don't have are any of the cables or hardware that is suppose to go between the handle and the rear wheel cables.
Can anyone point me in the right direction on where to find these cables? Ive hit up a couple of reproduction sites asking for help and all they tell me is that they don't make this for the 60-66 series. I don't really want to go the lokar route because my son really wants to stick with the stock \ vintage look that the handle gives him. Pictures are here: http://www.flickr.com/photos/7728263...57627191456461 http://www.flickr.com/photos/7728263...7627191456461/ http://www.flickr.com/photos/7728263...7627191456461/
Glenn Cumming, Ga (68 C/10 Fleetside LWB 307 (64 C/10 Fleetside Shorty Custom 350, with 73 donor parts aplenty) (2001 Porsche Boxster S - 168 MPH of fun) (2005 Chevy Avalanche Z71 1500) |
07-30-2011, 12:58 PM | #2 |
Re: E-Brake emergency brake help
inline tube,excellent quality.you can get whole kit front to back or individual pieces.can also get them in stainless.for my 66 whole kit clips ,cables, everything in stainless was 185 bucks,i wouldn't look anywhere else!my 0.02 cents
07-30-2011, 03:26 PM | #3 |
Hey mud,
Do you have the e-brake crossmember and all the gimikus that goes with it? Check my build thread if you want to see how you can fab it all up if it is not with your truck. Good luck, TR
1965 C10 SWB Fleet Two owner LS2 Swap Thread http://67-72chevytrucks.com/vboard/s...d.php?t=413880 |
07-30-2011, 03:41 PM | #4 |
I have the crossmember but nothing else other than what I have pictured.
07-30-2011, 05:05 PM | #5 |
Here is what the stock linkage on the cross member of my 65 looked like.
TR
07-30-2011, 05:46 PM | #6 |
gotmud,
if you want stock and you have that piece, I think you can buy the rest of it. If you just want to keep the handle under the dash and have park/emergency brakes... you can use the 1966 C10 and later style system. 1966 C10 park brake cable routing I used the later system on my '65(auto 3 speed tranny and I had no ebrakes when I bought it), it will hold the truck stopped on a hill... Good luck. -W |
07-30-2011, 06:17 PM | #7 |
Hey gotmud...
I was looking for something else entirely just now and stumbled on this thread "parking brake for 1965 c10" ... may or may not help. -W |
07-30-2011, 11:00 PM | #8 |
The 60-66 GMC/Pontiac guy....
Good thread
Building Genuine Pontiac Firepowered cars and trucks for several decades. Why Pontiac?? That's just me daring to be different. Projects.. 63 C10 Short Wheel Base fleetside (The Pro-Street) currently under reconstruction. 440CID 2X4 Pontiac |
07-31-2011, 10:45 AM | #9 |
Thanks TR and ROO.....thats what I needed.
08-01-2011, 09:23 AM | #10 |
I am using a Lokar cable kit with the stock handle. Luckily the first few feet of the original cable is in place. I think LMC sells this key piece. I am not using any of those pictured linkages.
The steel C-shaped link between my drum brake shoes was missing, so I had to find a couple of those before I could complete the install. |
08-01-2011, 10:51 AM | #11 |
Here is a picture of my 66 e brake cable without the body on. Kieth
http://kieth.smugmug.com/Trucks/66-G...536_X5Lck-A-LB here you can see the routing through the crossmember (in front of the new fuel pump) http://kieth.smugmug.com/Trucks/66-G...53807607_FXS8x Here one can see the cable against the trailing arms: http://kieth.smugmug.com/Trucks/66-G...314_YR2X5-A-LB |
