Old 07-30-2011, 08:05 PM   #1
NtheFamily
NtheFamily's Avatar
SB to BB in '85 4x4
I have a '85 4x4 with a 305 now and plan on building a '77 454 to put in it's place. Is there a past post that has a lot of info I will need to perform the swap? If not, is it a pretty easy swap? Will I need to swap motor mounts/perches? What style of HEADERS would fit? My truck has the heavy duty suspension, so will the front suspension be able to handle the BB? Will the 700R4 be able to handle the 454?
Thanks for all the info you can give me. I've swapped SBC's with SBC's, but never delt with BB's. I don't think I have nothing to loose swapping motors, but just wanted a little more umph when I need to pull something. I get 9 MPG now with the 305, which want pull a greasy spoon out of a cats a$$.
NtheFamily is offline   Reply With Quote
Old 07-30-2011, 08:21 PM   #2
baclay9
Re: SB to BB in '85 4x4
454 will go right in. Make sure the fuel pump on the 454 is for a 4x4. There is a difference.
baclay9 is offline   Reply With Quote
Old 07-31-2011, 08:14 AM   #3
NtheFamily
NtheFamily's Avatar
Thanks for the info on the fuel pump.
What headers will work on this setup?
Old 07-31-2011, 08:52 AM   #4
baclay9
I have a 2 wheel drive that I swapped a 454 into and I went with Sanderson BB8 headers. They are awesome! They will fit your 4x4 as well. They are a 3/4 length header with 1 7/8 primaries. I put out a little extra and got them ceramic coated.
Best thing is they have a no gasket flange. You just run a thin bead of black permatex rtv around them and no leaks!
Old 07-31-2011, 05:46 PM   #5
NtheFamily
NtheFamily's Avatar
Would anyone have an opinion on putting in a 383 versus the 454? Just curious as to what your thoughts are.
I have a 4 bolt block to build a 383, and a 454 to build. Just curious as to others thoughts, ideas etc.
'65 Chevy Fleetside
'85 Chevy 4x4
'92 Chevy s10
Old 07-31-2011, 10:17 PM   #6
cheepin
That would be all preference.The 383 will rev higher and give more power at topend.454s tend to be more lowend torque.so it depends on what you are doing with the truck.Towing go 454.
1984 1ton 4x4 crew cab dually 6.2 diesel,465,205,D60,D70,1987 3/4ton 4x4 suburban 5.7 FI350,TH400,208,1985 CJ-7 FI406,465,205,D60,FF14, 1970 Jeepster 350,465,205,D44,FF14,
cheepin is offline   Reply With Quote
Old 08-01-2011, 07:13 AM   #7
b454rat
A 454 will rev just as high as a 383. The simplest would be the 383, it will bolt in with zero mods. A mild built 454 will embarrass a 383.....
2000 Chevy Tahoe Limited 3/5" drop
2000 GMC CCSB 454/4L80 6” lift SAS
1999 Chevy CCSB 454/NV4500 4” SAS
1999 GMC Yukon stock SAS 6"
Old 08-01-2011, 05:57 PM   #8
NtheFamily
NtheFamily's Avatar
b454rat, what mods would have to take place? Thanks for any and all info.
'65 Chevy Fleetside
'85 Chevy 4x4
'92 Chevy s10
