Disc brakes
Does any one know if the factory front disc brakes from a 67 1/2 ton 6 lug fit on a 66 1/2 ton 6lug. Want to put disc on the 66. found a 67 with disc.
Re: Disc brakes
not factory in that 67 they aftermarket
read up on board rules about double posting
#3 | |
67-72 parts collector,…
![]() Join Date: Nov 2002
Re: Disc brakes
IF you can get EVERYTHING off this '67 truck,... you can swap it over to your '66. You will need: -A-arms -spindles assemblies -All of the steering -Master cylinder The steel brake lines will be different also. Please explain what you plan to do. It won't be a bolt in swap.
