Old 08-01-2011, 06:17 PM   #1
68c20lwb
68c20lwb's Avatar
where does the clutch ball mount on my 454?
my truck is factory SBC and i am converting it to BBC. don't everything correctly so far and now i have a major issue because i am moving and need it running and driving.
there was a bracket on my SB that bolted to the block above the oil filter. on my BB there is one hole for a clutch ball above the oil filter? does it use the same Z-bar location? need HELP thanks so much folks!!
1968 C20 450hp 425ft-lbs 454/SM465 4.56's 2004 HD rims, needs paint and a 5th gear!
1969 C30 Open Road Motorhome 350/th400
1972 K10 350/350/205 Daily Driver -SOLD
68c20lwb is offline   Reply With Quote
Old 08-01-2011, 06:20 PM   #2
68c20lwb
68c20lwb's Avatar
Re: where does the clutch ball mount on my 454?
pictures would help a TON!!!
Old 08-01-2011, 10:44 PM   #3
fredm98
Active Member
Check out post #5 here http://67-72chevytrucks.com/vboard/s...d.php?t=334035
Also not sure what your SB one looks like but here is one I saved from a 402. I know this isnt the for sale board but let me know if you need it.
fredm98 is offline   Reply With Quote
Old 08-01-2011, 11:25 PM   #4
Shyguy
Junior Member
Shyguy's Avatar
I got the one for my 454 from Auto Tire and Parts (Napa). It was a ball with a threaded end.
The way we mounted the engine we did have to move the mount on the frame to get a good angle.
'67 Chevy C-20 short stepper - build complete, 454/SM-465.
'75 C-30 Single Cab DRW-350 small block/NP-435.
'77 GMC-6500 Dump Truck, 427 Tall Deck.
'92 GMC K-3500 Duallie, 454/4L80E.
Shyguy is offline   Reply With Quote
Old 08-02-2011, 11:43 AM   #5
SOON2BLAZE
SOON2BLAZE's Avatar
The zbar from the SBC should work, one did on my BBC. The angle may be a bit funky as mentioned above. You may need a bracket or you may be able to use the threaded hole in the block. Its kinda one those deals you wont know till you get the engine and trans stabbed in there. Another Idea I kinda kick myself for not doing is a conversion to a hydraulic throw out bearing. Smoother clutch feel and elimantes the angles and parts. While I'm not a fan of LMC parts, their catalog has a great view of all the parts needed for the z bar set up
SOON2BLAZE is offline   Reply With Quote
Old 08-02-2011, 08:31 PM   #6
68c20lwb
68c20lwb's Avatar
fredm98 i would love to purchase that! pm me your info and a price!!
Old 08-02-2011, 10:17 PM   #7
Monty
hmm... i can't wait to tackle the clutch linkage on my BBC/4x4 conversion.
Monty is offline   Reply With Quote
Old 08-02-2011, 11:09 PM   #8
68c20lwb
68c20lwb's Avatar
Yeah your gonna have so much fun!
Old 08-07-2011, 03:43 PM   #9
Shyguy
Junior Member
Shyguy's Avatar
I bought the clutch ball that screws into the block of a 454 at Auto Tire and Parts/Napa for around $12. The item number is 615-1197.
Just thought this might help some one some day.
Old 08-07-2011, 08:50 PM   #10
68c20lwb
68c20lwb's Avatar
did it line up with the Z-bar?
Old 03-20-2016, 08:15 PM   #11
RANDY COX
RANDY COX's Avatar
I'm getting ready for that conversion now any pointers..
1964 BBC 402 4x4
RANDY COX is offline   Reply With Quote
