![]() Join Date: Jul 2010
Re: Drum Vs. Disc
Drums
* Pro - Less expensive since they're already stock on most of our trucks * Pro - Drums work better then discs as emergency brakes * Con - They stop poorly when wet and can get clogged with mud * Con - Stopping power can fade with repeated hard braking * Con - Larger tires Discs * Pro - More consistant, straight line stopping power * Pro - Dissipate heat better to stay cooler * Pro - Less affected by water or mud * Pro - Easier to maintain and faster to replace pads then shoes * Con - More expensive to install (but maintenance costs should be less)
Mark 1972 C10 SWB LS1/T56 6 speed trans/4:56 posi with 5.5"-7" static drop/Boss 338 Wheels 18"x20" My build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=424609. My first start up http://youtu.be/R899YQ1OcjU |
