Old 08-03-2011, 12:15 AM   #1
CHEVY_BOI93
Transmission/Odometer Question
I have 1970 SWB. But the odometer/speedometer does not work. i know its not the gauge panel because i took a look where the cable that connects to the transmission and gears in there. and it doesn't spin. everything appears to be in there well. Any help/suggestions.
Keep in mind i have a 400TTH Tanssmission SB 350 Engine. the axle was custom made to fit the chevy transmission and the Ford 9 inch differential.
Please help
CHEVY_BOI93 is offline   Reply With Quote
Old 08-03-2011, 03:57 PM   #2
Wrenchbender Ret
Re: Transmission/Odometer Question
Raise the rear of the truck. Remove the speedo cable from the trans. With the trans. in neatral put a tiny srewdriver in the hole in the gear. Turn the driveshaft & see if the screwdriver turns. If not remove the bolt holding the gear holder & pull itb from the trans. Inspect the gear & the gear inside the trans. If one or both are stripped they will need to be replaced. It posible the inner gear came loose on the shaft & moved away. You have to pull the drive shaft & rear houseing to get to the inner gear.
Wrenchbender Ret is offline   Reply With Quote
Old 08-03-2011, 11:53 PM   #3
CHEVY_BOI93
i really appreciate the help.....but the last part that you said is a bit confusing. if you could clarify that for me please. I mean what do i do when i pull out the drive shaft what is it exactly that im looking for and or replacing.
thanks
