Semper Fi!!!
What are some common problems with 4x4s?
Im looking at a nbors 76 gmc 4x4
Brandon... "IT ONLY TAKES EVERYTHING YOU GOT!!" Semper Fi ![]() |
What Hump?
Re: What are some common problems with 4x4s?
Most common problem is tha they cannot pass a gas station!!!! But their a good solid truck if it has not been rusted out. You'll want to check the power sterring drive gear, they have a bad habit of tearing out the frame area, but I believe there is a plate that can be welded on. Looks like the one your loking at has full time 4wd, no locking hubs.
Looks like a decent project, but I wouldn't go any higher than $1500 for it. Tom
Lil red 86 c-10 99 Sub 78 Camper Special w/ 454 |
Semper Fi!!!
#4 | |
K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
in my opinion its a 600$ truck. towards the south they are much cheap i picked up a rust free 2wd for 1k.
1985 C10 Custom Deluxe LWB 305/700r4 [ Goldfinger ] ![]() 1999 k3500 crew cab dually 6.5tdi/4l80e |
yep frame cracking like mentioned, the plate can be welded on in addition to either fabing ur out brace or buying a brace that also bolts in. If u get serious about it I can send u pics or start a thread about my weld in plate and my own brace I fabbed.
Even if the frame is not cracked yet, it probably will, at a min do the brace or weld in plate, both if ur running 35 and some offroading. If the drive shaft is missing I assume the 4x4 is broke. |
Semper Fi!!!
Yes sir, NC truck with minimun* rust. The floors are worst part. The corners and rockers is like new. The floors have some rust holes but there not as bad as Ive seen. I was thinking $600 is the most I would offer to.
#8 | |
Semper Fi!!!
#9 | |
Semper Fi!!!
^ haha I know what you mean
For that truck, I would start out around $750, and wouldn't go higher than about $900. it needs a lot of work. Interior, as you mentioned. Paint. Assume the 4wd doesn't work, even if the owner says it does. if it's been sitting a while, as it looks like it has, you're gonna have quite a few bugs to work out. Check it out really good, and drive it if all possible, before you offer anything for it. And start low, real low.
Looks like a 4" lift.
You only need two tools in life - WD-40 and Duct Tape. If it doesn't move and should, use the WD-40. If it shouldn't move and does, use the duct tape. If a hammer doesn't fix it, you have an electrical problem! Slot Cars, 1:24 Scale, 100MPH@100,000RPM, fastest things on wheels! ![]() |
ive got a 84 shortbed k10, mine was in similar shape as that, i picked it up for 500 bucks, the frames do crack, and with that truck sitting i would check out the gas tank, mine was leaking, along with a few others that i bought, easy fix but something to check for...also i had a bunch of electrical issues with mine..easy fixes once you find them
#13 | |
Semper Fi!!!
The usual no broken springs no cracked in the spring mounts. usually the shocks don't get changed often so they are something to look at. make sure the bearings are good and greased.
#15 |
Semper Fi!!!
Alright thanks guys, Im going to look at it again and I will take lots of pics and they will be better quality haha
#16 |
I'd expect 4, that way when you get 6 you'll be happy.
"I'm Dirk Diggler enough to own and operate a vehicle of this caliber" -veinbar Dropped and LS Swapped SWB 87 Build Thread |
#17 |
Semper Fi!!!
#18 |
