Old 08-02-2011, 01:02 PM   #1
lukbrw
lukbrw's Avatar
Helper bag kit
Hey guys, need a little help. I'm looking at putting in some help bags just so I have extra support when pulling our boat. I've seen a number of posts with guys doing the same.
I know they don't make a specific kit for the 72, but what kits are you using? I contacted Jegs and they said they don't have a kit.
If you have a specific part number, that would be greatly appreciated.
THANKS!
lukbrw is offline   Reply With Quote
Old 08-02-2011, 03:37 PM   #2
haysonj
haysonj's Avatar
Re: Helper bag kit
THANKS!
I don't know if you have trailing arms or leaf springs but I put the Air Lift Kit on mine with leaf springs http://www.autoanything.com/suspensi...0A2406009.aspx
69 Chevy 4x4 383 Power
haysonj is offline   Reply With Quote
Old 08-02-2011, 03:55 PM   #3
vectorit
What?
vectorit's Avatar
Re: Helper bag kit
I have a set that I took out of a 67 leaf sprung burb.
Don't know who made them, but they don't look at old.
So, they are out there.
Chris
1968 K20 Suburban
1972 K10 LWB PU
vectorit is offline   Reply With Quote
Old 08-02-2011, 04:54 PM   #4
lukbrw
lukbrw's Avatar
Re: Helper bag kit
Trailing arms. No leafs.
Old 08-02-2011, 07:19 PM   #5
haysonj
haysonj's Avatar
Re: Helper bag kit
Did you look at the Air Lift 1000 in the link I posted above. It fits open coils and is only $90
Old 08-02-2011, 08:57 PM   #6
SCOTI
SCOTI's Avatar
Re: Helper bag kit
Just swap bags in place for the rear coils. Leave them @ 30-40psi unloaded & add some air via a simple schrader valve set-up when you plan to load it down. You would be purchasing 2 bags regardless right?
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 08-02-2011, 10:40 PM   #7
AusTx68
AusTx68's Avatar
Re: Helper bag kit
If you go this route you may want to consider adding a rear anti sway bar.
'68 C-10 SWB 383 Stroker (Sold 3/2/2013)
'87 R2500 LWB 454 TBI converted to Carb
AusTx68 is offline   Reply With Quote
Old 08-02-2011, 11:25 PM   #8
SCOTI
SCOTI's Avatar
Re: Helper bag kit
Not really a 'must have' but sure won't hurt. The bags won't be any worse than coils; they'll just allow for height/capacity adjustability where coils won't.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 08-03-2011, 07:59 AM   #9
lukbrw
lukbrw's Avatar
Re: Helper bag kit
Actually, we like the truck just the way it is. If we decide to do a frame off restore or go more custom, then I would concider just going bags in all corners.
But really, we're just looking for something to help make it a little safer when going down the road to the boat launch. Plus the helper bags seem pretty easy to install and just use when needed.
Thanks for the link.
Old 08-03-2011, 08:37 AM   #10
SCOTI
SCOTI's Avatar
Re: Helper bag kit
It's your truck & your decision..... Air bags in place of coils aren't strictly for the 'custom' crowd. They were intended for hauling cargo while providing a better ride quality.
'Helper' bags for coil applications go inside of the coils meaning you would remove the coils for the installation unless your going to do some sort of 'custom' set-up. If you're removing the coils anyway, just bolting in an air-spring that replaces the coil is easier. Regardless of which way you go, you still have to route air to the bag to be functional so that's a wash.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 08-03-2011, 08:57 AM   #11
NovaOne
Re: Helper bag kit
Someone on here is using these. I've been saving the link for myself. http://www.performanceonline.com/196...DE-ASSIST-KIT/
NovaOne is offline   Reply With Quote
Old 08-03-2011, 11:08 AM   #12
lukbrw
lukbrw's Avatar
Re: Helper bag kit
I've seen them also. If I was going to spend the $250, I would just go with swapping out the coils for bags.
Like I said, we like the stance the way it is. Just looking for something to stiffen up the back end. At $85, the helper bags seem the best route.
Old 08-03-2011, 01:28 PM   #13
SCOTI
SCOTI's Avatar
Re: Helper bag kit
Link for what you intend to use?
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 08-03-2011, 03:07 PM   #14
haysonj
haysonj's Avatar
Re: Helper bag kit
I think he is looking at the link in my first post for the Air Lift 1000
Old 08-03-2011, 03:54 PM   #15
lukbrw
lukbrw's Avatar
Re: Helper bag kit
That's correct...
Old 08-03-2011, 04:00 PM   #16
Jack_71C10
Shortbed club member
Jack_71C10's Avatar
Re: Helper bag kit
Someone told me these would work, so I saved this link.
http://www.sdtrucksprings.com/index....oducts_id=6894
71 custom/10 6.0/4L80E SWB ece 4/6
72 custom camper 350/3 spd
2020 Chevy Express 3500
2023 Hyundai Tuscon
1986 GMC 3500 Bucket Truck
Sent from my Rotary Phone via 14.4kb/s modem.
Jack_71C10 is offline   Reply With Quote
Old 08-03-2011, 04:33 PM   #17
lukbrw
lukbrw's Avatar
Re: Helper bag kit
Unfortunately the kit from Auto anything is only for the 1 ton. I've seen guys with kits......anyone else know???
Old 08-03-2011, 04:44 PM   #18
SCOTI
SCOTI's Avatar
Re: Helper bag kit
Description from the AirLift 1000 front kit posted:
•The perfect helping-hand for your open coil springs, giving you up to 1,000 lbs of leveling capacity
•Fine-tune the level of dampening for the right mix of load support and ride quality
•Tough polyurethane construction is custom-molded to fit your springs
Made just for open coil spring suspensions
The text states these are for open coils & that they can be used front & rear. But, the rear coils in this application are not 'open'; they're pigtailed (closed) on both ends. Do they make something similar that works w/the closed type coils?
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 08-03-2011, 04:54 PM   #19
Andy4639
Old member
Andy4639's Avatar
Talking Re: Helper bag kit
I love mine.
I ran the air lines back to the bumper and made them the tag bolts!
Oh man it made a differance in the ride. No more bouncing when I go over small humps in the road.
Man I need to move those shock's one of these days.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 08-04-2011, 07:59 AM   #20
lukbrw
lukbrw's Avatar
Re: Helper bag kit
Yours are the pictures I've seen. Do you remember what kit you bought?
Old 08-04-2011, 10:42 PM   #21
Andy4639
Old member
Andy4639's Avatar
PM sent!
