Old 07-28-2011, 11:50 PM   #1
87chevy.com
BMW & ASE Master Certified
87chevy.com's Avatar
DBW pedal question
Just wondering if it makes a difference between what pedal I use if I use a DBW throttle body. I have not picked up my donor motor, but I will have to use an F-body intake... my latest project is LS into a e46 (bmw). The bmw had a DBW system already, pedal assembly has the same wire diagram as the truck, 2 potentiometers, low voltage reference, 5v and signal... Just wondering if anyone has mix mached TB and Pedal before... not sure if I can modify the BMW pedal to make it cable..?
clint
1987 Silverado - L83 5.3 w/ 6L80e ,A/C,P/W,P/L,TILT, HID projectors, Wilwood C-10 Pro Spindles w/ 2018 silverado front brakes & C-5 Corvette Rear Disc Brakes
1999 BMW 528i - 5.7 LS1 w/ 4l60e, Ford 8.8 IRS w31 spline posi & FX-r projector retrofit
New project: 2006 BMW x5 6cyl AWD to L83 6l80e 4wd to 2WD / RWD
A poor man buy's it twice
finally got my domain name back, 87chevy.com.... site rework in progress
87chevy.com is offline   Reply With Quote
Old 07-29-2011, 12:52 PM   #2
Ackattack
Ackattack's Avatar
Re: DBW pedal question
I highly doubt a BMW pedal would work with a GM engine.
I've even heard that its best to use the gas pedal and TAC module from the same vehicle.
Ackattack is offline   Reply With Quote
Old 07-30-2011, 12:46 AM   #3
87chevy.com
Im sure it wont work, but I wonder what the differences are? they both have the same wiring signals on paper... hurm... to make things easier, I'll give up the thought and headach and just figure out how to get a regular cable gas pedal fitted and looking good in there
clint
Old 07-30-2011, 02:23 PM   #4
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
just get a gm pedal and tac assembly that match and use the dbw throttle body. No reason to convert to DBC just because your bimmer pedal won't work.
Because of how particular the dbw systems are, I would be surprised if the pedal was compatible. However BMW has sourced parts from the GM catalog before so I wouldn't rule 100% against it. I'd like to hook it up to a tac and tb and see how it reacts. Maybe there could be a breakthrough for the bmw swap guys.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 07-30-2011, 04:36 PM   #5
TR65
TR65's Avatar
87,
I used a GM pedal, same year, etc. The ECM set a code that basically said, "I ain't gonna run this engine with that pedal". I had to get an exact match for the ECM / Engine.
Anyone need a pedal? I don't know what it would work on.
Good luck,
TR
1965 C10 SWB Fleet
Two owner
LS2 Swap Thread http://67-72chevytrucks.com/vboard/s...d.php?t=413880
TR65 is offline   Reply With Quote
Old 07-31-2011, 11:49 PM   #6
mcbassin
Still Learning
mcbassin's Avatar
What if you don't know what model engine you have? I was told mine is a 2003 but I was also told it was a 5.3 it turned out to be 4.8. Is there are way to know which DBW pedal it takes? What does the TAC module box look like anyone have a pic? thanks
Old 08-02-2011, 03:44 AM   #7
ls1nova71
ls1nova71's Avatar
It doesn't matter as much what engine you have. The TAC and pedal and throttlebody need to match the PCM/tune. Google the service number on the PCMand it should give you a year, or check the VIN in the PCM to find out. Then get a marching TAC and pedal. The TAC is a little plastic and metal (or all plastic it depends on year) box about 1x4x6 inches with 2 plugs on it. Look at the second post in the" show your Ls engine bay" thread, and you can see mine mounted to the firewall about where the distributer should be.
ls1nova71 is offline   Reply With Quote
Old 08-03-2011, 07:32 PM   #8
Chevy4Life
Chevy4Life's Avatar
There is some good DBW info here:
http://ls1tech.com/forums/conversion...silverado.html
Chevy4Life is offline   Reply With Quote
Old 08-03-2011, 10:14 PM   #9
usmcchevy
Has more rust than truck...
usmcchevy's Avatar
Best pic I have of my TAC.
1972 Custom/10 SWB, 4.8/4l80e
Build thread
LSx Swap FAQ index
usmcchevy is offline   Reply With Quote
Old 08-03-2011, 10:59 PM   #10
mcbassin
Still Learning
mcbassin's Avatar
Thanks guys. I need all the help I can get. this ls stuff is pretty foreign to me. I'm pretty sure I have one of those boxes. Maybe all I need is the pedal?
