08-04-2011, 01:58 PM | #1 |
no bolts in bed
So here I am driving to fill the tank up. I just got the truck on the road about two months ago but havent been driving it much since Im still doing a little work. Im driving down the road and notice the bed is sliding back and forth. Come to find out the PO never had the bed bolted down. It only slid slightly to the left but now the holes dont match up. Do I need to lift the bed to get it lined back up or is there anyway I can slide it over that wouldnt necessitate a lot of help?
08-04-2011, 02:02 PM | #2 |
Re: no bolts in bed
there should be a small rubber pad between the bed mount and the frame mount, you will need to lift it, line the bolt holes up and place the pad in correct spot then lower the bed and bolt it down, leave them all loose untill you have it right where you want it, then tighten them up.
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 support our troops! |
08-04-2011, 04:00 PM | #3 |
Re: no bolts in bed
when i bought my truck i had the same deal the last owner did bolt the bed down. i had to stop at lowes and got 4 in long bolt and nut, also some rubber. its was like 10 buck for everything.
08-04-2011, 04:12 PM | #4 |
Re: no bolts in bed
You can clamp a piece of 2" medium or heavy wall square steel tubing or a 4x4 across the bed rails and then lift the bed up with an engine hoist.
I don't think there is more than one bolt currently in my bed. |
08-04-2011, 06:31 PM | #5 | |
Re: no bolts in bed
Name: Rich Current Ride: 1964 C-10 Short Fleetside Daily Driver: 2005 GMC crew cab short fleetside /2001 Chevy Tahoe Past GM Trucks: 1959 GMC short stepside 1968 GMC short stepside-4x4 1973 Chevy short stepside 1989 Chevy short fleetside-reg cab 1993 Chevy short fleetside-Xcab 2002 Chevy short fleetside-Xcab Save the dinosaurs, use synthetic oil. |
