Old 08-04-2011, 09:45 PM   #1
mcbassin
Still Learning
mcbassin's Avatar
Which LS mounting plates? Help
I'm trying to decide which engine mounts to build for my engine install.
This is my motor mount stand style (73 up I think) Clamshell mounts. Bobs pics borrowed.
I need to know which one of these 1, 2, or 3 with a 67 frame with 4.8ls with stock AC compressor location and 4L60E tranny.
I want my engine to be in the optimum position to use the original driveshaft if possible. I really don't want to cut my frame either.
Anyone use this setup on their swap? Help?
Old 08-04-2011, 10:01 PM   #2
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
Re: Which LS mounting plates? Help
well....your trans will be a bit longer, so if you have clearance up front, maybe you need #2. Are you planning on using the clutch fan or going to e-fans?
That said, I used #1 on mine and got a new d/s made.
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
Old 08-04-2011, 10:18 PM   #3
mcbassin
Still Learning
mcbassin's Avatar
Not sure what fan yet. What did a an 03 engine have on it? electric or cluctch? I can't remember if I have a fan or not? Probably just go electric more than likely.
Old 08-05-2011, 12:39 PM   #4
68GMCCustom
I can't remember when they started. I had a dual e-fan setup on my '01 Sierra C3 that came from a newer truck... but not sure of what year. My '01 PCM had no problem running them tho.
Kurt -
Old 08-05-2011, 01:48 PM   #5
Ackattack
Ackattack's Avatar
Are you planning on using the lsx A/C compressor in the stock location?
If so:
#1 won't work
#2 probably won't work
#3 should work.
I made my own adapter plates (style #3) on some tubular engine stands. I have a set of adapter plates like style #2, but they would not work cause of the A/C compressor. That being said, I have an F-body A/C compressor on corvette accessories. So the truck set up may be slightly different sized and allow you to run that set up.
Also, My engine stands are set back as far as possible. Can't remember if that is considered the "6 cylinder position" or not.
Ackattack is offline   Reply With Quote
Old 08-05-2011, 02:00 PM   #6
mcbassin
Still Learning
mcbassin's Avatar
If so:
#1 won't work
#3 should work.
Yes I am planning to use the stock Ls a/c compressor.
I have considered using the 6 cyl. position. I'm just trying to cut corners and hoping to find someone with the same setup I want to use. That way I can just make one set and be done.
Old 08-05-2011, 04:11 PM   #7
mcbassin
Still Learning
mcbassin's Avatar
Did any of you guys actually make a drawing of any these plates when you made your own? In Bob's thread I found 5/16" thick by 4.25" plates but didn't find dimensions for the length and how far from the edges to put the hole patterns?
Old 08-05-2011, 04:17 PM   #8
Ackattack
Ackattack's Avatar
I just kinda made them by taking some measurements off the engine and mounts:
Old 08-05-2011, 04:26 PM   #9
mcbassin
Still Learning
mcbassin's Avatar
Thanks Ack, that is what I'm trying to avoid test and measure. I don't have an engine lift and am going to have to use an A-frame (not the easiest for motor fitting).
I want to build the plates mount them up and go if possible. I am pretty short on my engineering patients right now. I will make a drawing once I get some that work and post it up on Bob's thread.
Old 08-05-2011, 04:35 PM   #10
Ackattack
Ackattack's Avatar
I could swear I saw a drawing with all the dimensions for them somewhere.
Old 08-05-2011, 10:57 PM   #11
68GMCCustom
here you go:
Kurt -
Old 08-05-2011, 11:04 PM   #12
mcbassin
Still Learning
mcbassin's Avatar
here you go:
Thanks. I saw these drawings. But they don't give the dimensions of the plates and the hole patterns relative to the edges of the plates.
Old 08-06-2011, 10:45 PM   #13
68GMCCustom
the rest is easy no?
Kurt -
