1987 Chevy pick-up HELP. Please
Hi guys, this is my first thread and post ever and I really need your help.
Here is what I got. 1987 Chevy Pick-up, 1/2 ton, 2 wheel drive, 305, fuel injected, throttle body. Duel fuel tanks Here is the issue: I have been gone for 90 days for work, semi deployment if you will, and when I get back I get in my old truck, that I love, and it's hard to start, then it starts and runs for a minute then dies. Fuel issue right? Maybe not. I get it running and drive it, then it dies at the fuel station, when I stop. Get is started again, lots of cranking and drive it home. Then it dies again. Long story short, if you keep your foot on the throttle, it will run, IF you can get it started at all. I switched the tanks via the fuel tank selector switch. Same problem. Now, it won't start at all. It is cranking fine, and it wants to start, but it won't. Now, I think it has 2 fuel pumps, 1 in each tank right? Well, both didn't go out right? So this makes me think it could be an ignition module. I saw a thread on here where a guy sort of the same problem. I need help badly. Ignition module? Both fuel pumps? Ignition coil? Thank you in advance fellas. I really need some help on this one. |
BAD BOW-Silverado XST
Re: 1987 Chevy pick-up HELP. Please
Welcome to the site. First, pour a little fuel down the throttle body. Crank it. If it runs for a few seconds, the problem is fuel related. If it does not run, then I would suspect an ignition problem. Another problem is fuel. Today's blends use 10% ethanol, if we believe that crap. Over time, the mixture seperates and attracts WATER!! If you can pump out all the fuel and put fresh fuel in it. Replace the refuel filter.
Check for spark before pouring fuel down the throttle body. You want to know spark is there first. Pull a wire off one of the spark plugs. Put a screwdriver in it. Lay it across the frame rail or exhaust. Crank it. It should spark. If it does not, remove the ignition module and replace it. Since it started previously, I doubt it could be bad. Ignition modules do act up when they heat up. Have it tested at a parts store. |
Water in the fuel can be cured by dumping a bottle of HEAT into the tank. It will break up any water into tiny amounts than will pull through the engine without putting out the fire. It's used in the frozen north to help running in sub-zero weather and eliminates moisture formed by condensation.
#4 | |
Makes me think it's an ignition module or coil. I am going to replace them both. It sounds like when it gets hot, it shuts off or acts up. But it's weird. Have you ever seen anything like this? This is crazy. |
Slots go on anything!
You could have a problem in the tank switch also. It triggers the fuel pumps in an '87. That, or perhaps the switching valve.
1974 Jimmy- 5.3/4L80e/NP241 |
I had a very similar problem and it was my ignition coil. Switch it out and it came right to life. When they are going bad it seems like they can cut out at weird times.
86 C20 2wd with 454 and Turbo 400 |
Chevys Kick A$$
Yep x2 my buddy was going through the same thing as you and thought it was the fuel pump or starter! Turn out to be the coil. Let us know what you figure out as soon as you get the new parts in. Good luck
*HOODS is what I answer too* -'79, '77, '88 Pickup Sold, '85 Camaro, '83 T/A, '81,'83,'90 K5 Blazer All Sold -'79 3/4 ton "Big Yellow Bananna" Lifted 4spd. 39.5 TSL Swampers, The money Pit ![]() -'86 K5 Blazer Silverado 6.2 4" lift 35"s -'95 Ext. Cab Shorty 4" Tuff Country rolling 35" M/T's -'83 Monte Carlo T-Tops. 126,500 Original Miles -LATER ![]() I would rather push a Chevy then drive a ford!!
78K & 79C Jimmys
do you hear the pump(s) before cranking it
my 87 burb had a crack/cut in the wire that went hard baked and green found it over the wheel well with no noise from the pump i changed it and it worked for a bit then quit again,using a meter then i figured it out since you guys prob use more salt on a steak then your roads prob not it
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 |
If it was the ignition moodule it would die suddenly and not start at all. Coil, could be.
Definitely check your tank switch. Mine was bad and was causing the fuel pumps to short out. Since it is fuel injected, make sure you get the 2 position switch, not the carb switch that is a 3 position momentary switch. Also, coming out of your fuel pump relay there should be a red wire that is not connected to anything. Have someone turn the key to the on position, but don't start it. Have a meter on the red wire and you should see voltage come across. If you don't see voltage you might have a bad relay. Good luck with it, there are a lot of guys on here that know what they are talking about.
#11 | |
One thing though: I have replaced the tank selector switch in the cab. Is there another switch you are speaking about fellas? |
BTW. You guys are the best. This place is cool. Thanks so much.
If its not the fuel selector, I would lean toward the pickup coil in the distributor. They tend to act up on occasion, especially after it's been running a while.
Fawker Fab three seater rock crawler buggy 498 BBC/SM465/203/205 doubler, propane, 5.13's, 42" PB Rockers '66 C10 - The new hot rod '77 3+3 Dually - 12 valve 4wd conversion tow rig project '28 Ford 2 door sedan street rod RevLimit Offroad "Hang on beer, we can do this." |
#14 | |
Any help with this if it is? I am going to start with the coil and the module first, but I am seriously worried that it's the pickup coil. |
#15 |
If you have to pull the distributor, it's an easy, straight forward job that takes a little patience. Take a few minutes to search around the board for some real good, clear instructions and tips for doing it. If you need help, let us know, we'll walk you through it.
#16 |
Alright fellas, here is what I did: I just replaced the ignition module, and so far so good. I bought a new coil, but I couldn't get the bracket off of the old one to replace it since it's outside of the distributor cap. It has a housing right on one of the bolts. This housing has a cable running through it that goes to the injection, so I didn't want to mess with it.
Anyway, so far, so good. Thank you guys again for all your help. I really hope this module fixed the issue. From the sounds of it, Chevy's have had a terrible time with this module issue. Thanks again. |
| Bookmarks |
