Old 08-06-2003, 07:35 PM   #1
lukecp
Formerly yellow72custom
lukecp's Avatar
Brake light?
I just went in my truck, and the BRAKE light in the fuel guage was lit up, even though the key was off. I turned the key on and the light went out. Also, the needle on my cheap tach usually falls straight down when i turn off the key, but it went counter clockwise, towards the 8k rpm mark, and stopped there. The MC has plenty of fluid in it and the brakes work great. I disconnected the wire at the proportioning valve and the light stayed on.
Before i go mess with it after dinner, any ideas? Bad ground in the insturment cluster maybe?
'72 Chevy C10 Mild 350/TH350/3.07. Ochre/White. Old high school ride.
'70 GMC C2500 '62 327 4bbl/SM465/4.56-geared Dana 60. White/White. Project or parts truck.
'97 Saturn SL DD. 1.9/5-speed. 40+ highway mpg
lukecp is offline   Reply With Quote
Old 08-06-2003, 08:12 PM   #2
smallbigblock
I can't answer your question but I have a similar problem with mine. It flashes when the engine is running. The only way I can get it to stop is unplug it at the proportioning valve.
72 Cheyenne Super LWB
72 C-10 Short Stepside
71 Nova
smallbigblock is offline   Reply With Quote
Old 08-06-2003, 08:21 PM   #3
72BLAZERDUDE
72BLAZERDUDE's Avatar
Got the same problem with mine. Just unplugged it. First I thought it had something to do with a prop valve or mast cyl. Even thought maybe bad brake booster( Wanna a "A" ticket ride, disconnect the vacumn line fron your power brake unit and go drive it. Gives a whole new meaning to the word "whoa". It is probably just a bad sender.
72 2wd 307/AT/AC/TILT WHEEL
78 JIMMY HIGH SIERRA
72BLAZERDUDE is offline   Reply With Quote
Old 08-06-2003, 08:43 PM   #4
lukecp
lukecp's Avatar
Well, i just went and disconnected the "-" battery cable, then re-connected it and the problem stopped. Maybe the ground cable was just loose ??
Guess its fixed until it mysteriously pops up again later, lol
Old 08-06-2003, 08:53 PM   #5
old Rusty C10
Robert Olson Transport
old Rusty C10's Avatar
see if it comes back now tomorrow or after running the truck a while it could be possible theres a problem somewhere possibly the ignition switch or in one of the other in cab wwiring harnesses
Bob
1951 International running on a squarebody chassis
"If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board"
http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!)
PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport
Live each day to the fullest.. you never know when fate is going to pull the rug out from under you...
I hate cancer!!
old Rusty C10 is offline   Reply With Quote
