08-05-2011, 09:16 AM | #1 |
Tricks to getting door aligned
Got the door hung and I'm trying to get them set right. This is what I came up with. I mounted the dovetail and I have the door closed, with the help of a friend or two. holding the door closed, I'll lossen the bolts a little and slide/wiggle/shove/cuss and tap the door in place (I hope) .
How did you guys get it done? Jake
http://s1299.photobucket.com/user/jb...23904108567829 |
08-05-2011, 09:43 AM | #2 | |
Custom Builder
Re: Tricks to getting door aligned
1932 Chevy Roadster Car and Pick-Up - http://67-72chevytrucks.com/vboard/s...d.php?t=465709 1966 K20 Factory 4X4 - http://67-72chevytrucks.com/vboard/s...d.php?t=455484 (Sold) 1972 K5 Blazer (Sold) - http://67-72chevytrucks.com/vboard/s...ad.php?t=87530 2007 TrailBlazer SS - http://67-72chevytrucks.com/vboard/s...34#post4706534 |
08-05-2011, 01:06 PM | #3 |
I like to put a hydraulic floor jack with a 2x4 on it under the back/bottom end of the door (door slightly open/balanced on the jack) with the door hinges bolted mostly snug, then fine-tune adjust using the jack - saves some grunting and cussing. The paint stick trick is great for checking consistent gaps all around.
08-05-2011, 09:35 PM | #4 |
I'll try the paint sticks as I'd not like to smash the fingers. Thanks
