56 chevy stepside cab mounts
Ok I need a little help, I have a new cab mount set and I know the square rubber mounts go on the rear of the cab but what goes on the front mount on the outside of the frame? shims? rubber? nothing? I cant seem to find any pictures showing this. Thanks
Hollister Road Co.
Re: 56 chevy stepside cab mounts
You should have a thin rubber shim and a steel shim for the front. You may need more than one if the fenders don't line up.
Ok that makes sense now! Thanks for your help Dave
Tim |
OK, my thin rubber and steel shims are square like the rear rubber mount while the front mount is round. I assumed the shims went on the rear. ??
Dick 1955 stepside 1940 Ford coupe 1972 VW Super Beetle convertible |
#5 | |
Hollister Road Co.
The square or slotted steel shim goes on the front along with the thin rubber shim that looks the same and a bolt with a nut clamping them down. Sometimes when I disassemble these trucks I find multiple shims in the front or a rectangular shim on top of the rear top mount. You can add or remove shims to help get the fenders to line up a look ok at the door. |
