Old 08-05-2011, 10:23 PM   #1
CowboyProtectionUnit
CowboyProtectionUnit's Avatar
Crossmember Question
Ok I'm Doin a 2wd To a 4wd conversion on my 87-88 (squarebody) Crew Cab Dually... and the Plan is to do a Cummins Swap as well... Do I Need to Swap Out Engine Cross-members as well if I'm NOT planning on doing a lift... or less than a 4 inch lift??? Also I'm Putting a 6speed Manual in am I goni to have to chop and reweld the Tranny Hump in the Cab???
Eric "Target" Sherwood
Professional Bullfighter For Hire
God Bless and Gods Speed!
TheCowBoyProtectionUnit@yahoo.com
http://www.facebook.com/pages/Eric-T...59496227444241
CowboyProtectionUnit is offline   Reply With Quote
Old 08-05-2011, 10:52 PM   #2
STOCKISH
Formerly- 1972SuperCheyenne
STOCKISH's Avatar
Re: Crossmember Question
If you swap from 2wd to 4wd you are going to be swapping the crossmember anyway. I would just find a 4x4 frame and add the mounts and crossmember from Tennessee Diesel Conversions and you'll be way ahead of the game.
--Josh
My Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=799218
A good crossthread is better than Loctite any day.
Life is not about what you have, but who you have to share it with.
STOCKISH is offline   Reply With Quote
Old 08-05-2011, 11:06 PM   #3
hmmmmmmmmmmmm Like the Idear.... but kinda Cost Prohibitive at this Point in time The Cummins Is First on the List then the 4wd
Old 08-06-2011, 07:25 AM   #4
b454rat
If you go from gas to a Cummins you won't have to change the crossmember. But when you go to 2wd to 4wd, then you will have to change the crossmember. The oil pan is huge on the Cummins, it won't fit with the stock 4wd crossmember.
2000 GMC CCSB 454/4L80 6” lift SAS
1999 Chevy CCSB 454/NV4500 4” SAS
1999 GMC Yukon 350/4L60 6" SAS
Old 08-07-2011, 05:06 AM   #5
Can I Change Out the Crossmember when I get the Cummins to get it outta the way... and not worry about ground Clearance issues???
