08-06-2011, 07:44 PM | #1 |
Roadtrip!
Rear end ID please.
Pretty sure i know the scoop, but would like a second or third opinion. Thanks.
67 gmc custom lwb dakota truck. Sold...And bought back 69 swb 4x4 project (in progress) 70 c-10 lwb texas truck 70 4x4/BB/bkts/posi/tach(retired) 70 swb (wifes) 70 jimmy camper 71 K-5 factory 2wd 71 cheyenne 4x4/tach/posi/ plow rig 71 Cheyenne20 BB, buckets, tach, tilt, 4 speed 72 jimmy CST wyoming rig 72 jimmy Colorado rig 72 lifted texas 4x4 3/4 ton burb 65 fury conv. 383/auto 65 chrysler 300 "L" 413 auto |
08-06-2011, 07:50 PM | #2 |
member #16
Re: Rear end ID please.
4.11:1
john http://67-72chevytrucks.com/vboard/showgroups.php board vendors http://www.flickr.com/photos/1745471...7602865984234/ |
08-06-2011, 07:51 PM | #3 |
Isn't that a 12 bolt with 4:11 gears?
37/9=4.11
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs. |
08-06-2011, 07:53 PM | #4 |
Coil spring 12 bolt from a '66 2 wheel drive 1/2 ton with 4.11 gears. With an open diff.
08-06-2011, 07:56 PM | #5 |
Roadtrip!
And non-posi, correct? Also, is this a bolt in for the 67-72 trucks with trailing arms?
08-06-2011, 08:05 PM | #6 |
As Mike C says not a posi. You would see springs of some type in the center, some styles use springs, some use flat metal bent into an "S" type shape.
08-06-2011, 08:14 PM | #7 |
Roadtrip!
Thanks for the fast replies. You all confirmed what i was afraid of... 4:11 open diff. This was in a 66 swb forestry truck with a nice list of options... Including posi... I rolled the dice and lost this time. The spid is on the 66 message board.
Eric
08-06-2011, 09:54 PM | #8 |
Moderator
Every time I have come across a truck with posi listed on the spid, the rear end is either gone, or the carrier has been pulled and the rest of the guts are laying on the ground. Strange that it was pulled and the diff. cover bolted back on...must have been removed before it got to the yard.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man RIP FleetsidePaul |
08-06-2011, 09:58 PM | #9 |
Roadtrip!
Scott, the posi must have been removed ALONG time ago. The last plate was 88 and when i looked under the truck i could not tell that anything had been touched. The spid had posi on it and being a forestry truck, some one wrote on the dash to use posi additive... I just hoped it was still there.
08-06-2011, 10:05 PM | #10 |
Moderator
Dang Eric, I would have rolled the dice too. Did you try to rotate the tires before you pulled it? I always do that, unless the drums are frozen or driveline prevents it (that happens a lot)
08-06-2011, 10:12 PM | #11 |
Roadtrip!
No, the truck was sitting on the ground, it was 11:30, they close at noon. I barely had enough time to say cut it out for me. If i had more time i would have done that. While they were cutting it out, i was busy pulling 2 rims off another truck. (8.25x16.5 6 lug with the spring clips) plus my bonus was an NOS 66 pass rocker panel lying on the seat!
08-06-2011, 10:30 PM | #12 |
Moderator
That rocker was the icing on the cake!
08-06-2011, 11:11 PM | #13 |
Just like to part out trucks!!
I hate that when it happens Eric, I see on spid its a posi then get it home and it isn't, real frustrating, its happened a couple times to me I probably said the samething you did when you opened it up
67 Chev swb stepside 4x4 283 4 speed SOLD 72 blazer 4x4 4 speed Cheyenne 72 GMC swb 4x4 fleet 4 speed, original paint 1958 Cameo (one of 1405 built, it was my dads) 2020 chevy Apex 4x4 crew cab 1969 Z28 with the 302 1980 chevy swb 4x4 1964 chevell Malibu SS 1976 K20, sold new originally out of my dads chevy dealership Members that I've met, over 200 probably closer to 300 in the 12 years I've been on this site, everyone I met "It was a pleasure" |
08-07-2011, 10:53 AM | #14 |
Roadtrip!
Randy, there is only so much you can say...
Does anyone know if this is the same as 67-72? (bolt in) Any ideas on a value? Without a posi, i am going to sell it probably. $150????
08-07-2011, 12:30 PM | #15 |
Still Learning
Sorry for my ignorance, but how do you guys know that its a 4:11 by the numbers on the ring gear? Is there a chart to refer to? Chevy manual?
08-07-2011, 12:59 PM | #16 |
see the 9-37 on the ring gear, take 37 and divide by 9 = 4.11
08-07-2011, 01:44 PM | #17 |
Roadtrip!
That is correct. I believe that is the number of teeth on the ring gear and on the pinion.
