Old 08-06-2003, 11:52 PM   #1
Canadian694x4
Born To Lose Club
Canadian694x4's Avatar
Location: Calgary, Alberta/Oxenden, Ontario, Great White North
Cab Mounts...Part Deux
Does anyone have pics of there cab mounts and/or the bracket that is on the frame? I fanyone could post sum pics it would help me out.
Brian
Brian Smith - "Born To Lose"
1969 Chevrolet K10 LWB Fleetside - Proud Owner For 22 Yrs - 1 of 208 Built & Sold In Canada!- 283 V8/350TH/NP208, 2" All Spring Lift, 32" Good Year MT/R's.
1972 GMC K2500 Custom LWB Fleetside - Proud Owner For 3 Yrs - 1 of 571 Built & Sold In Canada! - 350 V8/SM465/NP205, 4” Rough Country Lift, 33” Interco TSL Thornbirds
2007.5 GMC Sierra SLE 2500HD 4x4 - Proud Owner For 17 Yrs- 6.6L V8 Duramax Diesel/Allison 1000, 2" Lift, 33" Mickey Thompson MTZ's.
2008 Yamaha Raptor 700r - Proud Owner For 15 Yrs - ITP Mud Lites.
2015 John Deere 1025R - Proud Owner For 8 Yrs - 24HP Diesel/H120/54D/260B/SB1154.
Canadian694x4 is offline   Reply With Quote
Old 08-07-2003, 12:10 AM   #2
Nelson
I seen a picture of the bracket alone on Ebay once. It had a picture.
Nelson
1970 C10 350 Auto.
A/C not Working
Nelson is offline   Reply With Quote
Old 08-07-2003, 12:33 AM   #3
68 Suburban
68 Suburban's Avatar
Is this what you want to see? This is what they look like in Arizona. I don't know what they look like after 30 years of winters in Canada.
Just sitting here contemplating contemplation.
68 Suburban is offline   Reply With Quote
Old 08-07-2003, 01:09 AM   #4
Canadian694x4
Born To Lose Club
Well I can say My Mounting Brackets look Cleaner then yours but My Rubber Mounts look craptacular (Cracked, etc.).
Does anyone have a pic of a mount from the top? I.E. some of you frame off guys? Plus are the mounts Riveted or bolted to the frame originally on our trucks?
Old 08-07-2003, 02:13 AM   #5
BUXMAN66
go bucks!
the forward mounting bolt (under your foot on d/s) is the one that is tack welded to the cab floor.....actually the washer is and the bolt goes down through the floor. the rear cab mount is put in from the bottom and up to the floor into a threaded nut tack welded to the floor.rear is pretty easy,... the front can be kind of a %itch! double check this info though cause this is on a 2wd. might vary on a 4x4. goot luck!
'68 swb 1/2t 350/350th
'86 lngbd 3/4 TON parts getter
'49 gmc 1/2 t 5 window 350/350th
'96 gmc sonoma sle ext-cab. hey it's a 4cyl. 5 spd and good on gas y'know?
BUXMAN66 is offline   Reply With Quote
Old 08-07-2003, 04:44 AM   #6
68 Suburban
Oh that is not my mount. It is a picture from one of the trucks I am selling. You can eat off the bottom of my burb
Old 08-07-2003, 09:45 PM   #7
Class of 69
Class of 69's Avatar
Mounts are riveted. It's getting too dark for a pic tonight, but if you still need one tomorrow, I can get one of a 2x4 frame.
69 GMC K10 ..some restoration required....still..
Class of 69 is offline   Reply With Quote
Old 08-07-2003, 10:29 PM   #8
Canadian694x4
Born To Lose Club
Pics are welcome...I think I've had a mount bracket replaced in the lifetime of this truck cause some mounts are riveted and bolted?!
