Old 08-07-2011, 06:07 PM   #1
treveiger
treveiger's Avatar
custom bending brake lines?
Just wondering if they had to be exactly bent as the factory or could they be different?
1969 Chevy c20(Miss Hackjob)
treveiger is offline   Reply With Quote
Old 08-07-2011, 06:27 PM   #2
Southcity
Southcity's Avatar
Re: custom bending brake lines?
They can be different, also which area on the truck are you referring to? from Master/proportioning to T fitting, cross member, to rear of truck etc.?
66 GMC Suburban Custom
66 Chevy K10 Suburban
Southcity is offline   Reply With Quote
Old 08-07-2011, 06:31 PM   #3
treveiger
treveiger's Avatar
As of right now im looking at just everything in the front of the truck. I'm going to try to copy them best as possible but might change it up if I can.
Old 08-07-2011, 07:49 PM   #4
Alex Hayley
I did mine in SS. Use a few wire hangers to get the shape you want. It is alot of work if you do not have the experience but the results can be great. The route can be different.
Alex Hayley is offline   Reply With Quote
Old 08-07-2011, 09:13 PM   #5
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
^^ Exactly.
I have bent my own before and have not followed the factory routing.
Gary
'cuz chicks dig scars...
I would never rebuild a 305.
Old 08-07-2011, 09:15 PM   #6
Hubscrub
Cruzin
Hubscrub's Avatar
do it the way you want, the flares are important to be right.
Lime Wife's 67https://www.google.com/url?sa=t&rct=...wZEMODaS2d94u8
Back to the Fifties 59 https://www.google.com/url?sa=t&rct=...NAeStpydfrcj_U
Proverbs 3:5,6
"Thanks to the Interstate Highway System, it is now possible to travel across the country from coast to coast without seeing anything."Charles Kuralt
In memory of our first baby daughter, daddy and mommy love you.
Danica Grace 6/26/14
Hubscrub is offline   Reply With Quote
Old 08-07-2011, 10:07 PM   #7
treveiger
treveiger's Avatar
I was thinking about getting the ones that are already flared
Old 08-07-2011, 11:04 PM   #8
bigsnookmaster
bigsnookmaster's Avatar
I bent and flared my own, and in the process I re-routed them away from all the heat sources.
bigsnookmaster is offline   Reply With Quote
Old 08-07-2011, 11:40 PM   #9
treveiger
treveiger's Avatar
Why away from the heat sources?
Old 08-08-2011, 02:13 AM   #10
sleepertruck72
sleepertruck72's Avatar
If you add headers they tend to be too close to the brake lines. They can boil your brake fluid That would not be good
72 C20 Longbed
05 1500 Z71
sleepertruck72 is offline   Reply With Quote
Old 08-08-2011, 09:24 AM   #11
bigsnookmaster
Exactly! Heat kills brakes! I really don't like the way the rear line comes up the pass side to where it goes over to the front crossmember. Way too close.
