305 vs 350
I have a dilema. I have a 86 chevy with a 305 v8 and a 350 lockup 3 speed trans. The trans is out, and the engine has very high miles. I can get the trans rebuilt and hope that the engine holds out for a good long while. If the engine goes out, I really would like to replace it with a 350 "however" the 350 lockup trans is a little weak for a 350( or so I've been told). I could just fix the trans and forget it but if the engine peters out on me I would need to stick with a 305 instead of a 350, which is really what I want. Any thoughts on this is much appreciated.
Robert Olson Transport
![]() Join Date: Oct 2002
Re: 305 vs 350
i replaced the motor in my 82 with a crate motor from jegs.. it was worth the upgrade from a 305 to a 350. I have a lockup convertor and my transmission hasnt missed a beat hauliung my boat, gravel dirt garbage etc
Bob 1951 International running on a squarebody chassis "If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board" http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!) PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport Live each day to the fullest.. you never know when fate is going to pull the rug out from under you... I hate cancer!! |
Re: 305 vs 350
i loved the 305 to 350 swap n mine tbi
Edited by staff |
Re: 305 vs 350
Maybe find a deal on a 350/th350 combo cheap? Shop around. My 83 4x4 was $550 and the 350/th350 works fine. It had a broken rearend. That cost me $150.
BAD BOW-Silverado XST
Re: 305 vs 350
Here is an option. Rebuild the 350th transmission if it needs it. Look for a low milage 96 and later 350. All 96 and later truck motors have roller cams. Remove all the electronics/FI and add an intake/carb. The 96 and later motors have great factory stock heads. You can even swap the cam for a little more power. It's easy to get up 300 HP out of a stock motor.
![]() Join Date: Jul 2003
Re: 305 vs 350
Here is a different take. Does the 305 use an excessive amount of oil, are you hauling or pulling heavy loads? Do you really nead a 350? Fix the tranny save your money and buy a 350 when and if the 305 finnally dies. I had to put a 305 in my 78 4x4 when the 400 ate a lob off the cam. It was the only thing available at the time that I could afford. I have driven the bat snot out of it, and yes it is piss poor on power but I cannot kill it. It can sit for months and starts right off.
For just putzing around or a daily driver, a 305 works. |
78K & 79C Jimmys
Re: 305 vs 350
went threw two 350s when i got it in my 78 burb
first was knocking a bit ended up a monti 305 worked out ok l stopped driving it for body rot
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 |
Re: 305 vs 350
#9 | |
78K & 79C Jimmys
Re: 305 vs 350
couldn't tell till the chain was off tho, timing never set up right, slight line from between teeth down then along under a few teeth that could lift up
Re: 305 vs 350
"Look for a low milage 96 and later 350." Another good idea!
Nylon gears was a stupid idea huh? |
78K & 79C Jimmys
Re: 305 vs 350
seems like it when everything else connected is steel
#12 | |
Re: 305 vs 350
I would just have the trans rebuilt and get by with the 305 if that's what you really want. I don't think a 350 would be "too much engine" for a lockup TH350 if you did decide on going that route. I plan on swapping a 400 into my '85 with a TH350. I'll see you at Oktoberfest with one of my Mopars.
'69 Dodge Charger R/T 440, 727, 3.55 Sure Grip '68 Plymouth Road Runner 383, 727, 3.23 Sure Grip '89 Dodge Diplomat ex cop car 408, 727, 3.55 Sure Grip '77 Dodge Monaco ex cop car 440, 727, 2.71 '79 Dodge 'Lil Red Express pickup 360, 727, 3.55 Sure Grip '12 Dodge Challenger SRT8 392, M6, 3.92 '85 Chevrolet C-10 SWB 2wd 305, TH350, 2.73 |
| Bookmarks |
