07-24-2011, 10:09 PM | #1 |
relocate gas tank help
i want to do a monster audio system in my 65 C10. in order to do that i need to remove the stock gas tank and find something that works under the bed. i want the same capacity or more if possible and i want to install the filler behind the driver side tail light. is there a tank kit that you guys would recommend for me. thanks for your help.
Hand Made Factory reproduction A/C vents text or call 602-361-6421 Website for A/C vents https://coolc10.com/ |
07-24-2011, 10:14 PM | #2 |
Re: relocate gas tank help
Thread here... http://67-72chevytrucks.com/vboard/s...d.php?t=445201
`64 C10 vortec 350/350/373 posi `69 RS/SS 350/350/308 `37 Ford 406/350/324 traclock `68 Dart 370/904/323 suregrip |
07-24-2011, 10:45 PM | #3 |
A blazer tank would work too I think. That has the filler coming out the side so you could route it out the tail light.
The advantage to the camaro tank....it's a pretty slick install in the sense that you're not having to cut the frame (just drill some holes). The only problem is the sender is a 0-90 ohm sender and won't work with the stock gas gauge without modification. It's an easy mod, just adding a resistor to wire going to the gauge, but I still haven't done it yet.
1966 C10 Long step build on a budget http://67-72chevytrucks.com/vboard/s...d.php?t=445201 no garage, no shop, limited storage space and tools....no problem. |
07-25-2011, 02:56 AM | #4 |
60-66 Nut
There are also aftermarket aluminum fuel tanks available from a couple of our board vendors. You can find them in the 'Vendor Marketplace' here on the forum.
http://www.67-72chevytrucks.com/vboa...ysprune=&f=195
07-25-2011, 08:47 PM | #5 |
try me and my son's you tube site we fab a big-10 auxillary tank behind the rear in my 80 c10 chevygearheads youtube i hope it help's good luck. PS the video's the gas tank we used was a 25 gallon auto zone GM 15 parts number
07-25-2011, 09:02 PM | #6 |
try me and my son's youtube site chevygearheads on youtube we fab a gas tank behind the rear maybe it will help you the tank is a autozone gas tank part number GM15 watch the video's good luck
08-09-2011, 12:28 AM | #7 |
Hope this helps.Tank inc 48 thru 51 Chevy passenger sedan.Fits best in frame,tucks up nice under the bed unlike most tanks on the market that hang low and are clearly visable from the rear.Check out my profile the fab work and tank are all there.
Lenguini. |
